end Lisp with if-function
Manuel_Kunde
Hi all, here is a snippet from a lisp.
At the end of diffrent commands, I want to ask the user if he want to do something more. How can I write in the if-function that if Request is "No", the Lisp is finished?
  (initget "Yes No")
    (setq request (getkword "Want to do something more? [Yes/No] ")
    (if (wcmatch request "Yes")
      (alert "i will do some more commands..")
      (if (wcmatch request "No")
      (alert "the lisp is finished")
I have added strcase, so you can also answer in lower case. If you don't do if for both cases, the program only terminates when "N" is present.
(initget (strcase "Y N"))
(setq request (getkword "Want to do something more? [Yes/No] "))
(if (wcmatch request "N")
 (vl-exit-with-error (alert "the lisp is finished"))
Edited by confutatis
  • Like 2
Try this:
(initget "Yes No")
(while (= (getkword "\nInsert new command(s) [Yes/<No>]? ") "Yes")
 (initget "Yes No")
;;Your command(s) here
 (alert "Continue") ;;For test
(alert "Bye") ;;For test
6 hours ago, BIGAL said:
nice acet function
Okay, that's simple and nice. What does the number 4 mean?
Is it possible to add a heading to the dialog box?
Add heading:
(setq yesno (acet-ui-message "Insert new command(s) [Yes/<No>]? " "MESSAGE" 4))
Last number 1:
Last number 2:
Last number 3:
Last number 4:
Last number 5:
Last number 6:
47 minutes ago, confutatis said:
Add heading:
I am excited, this is so amazing. Thank you for that.
For someone else who wants to do the same:
Base types
0 = Acet:OK
1 = Acet:OKCANCEL
2 = Acet:ABORTRETRYIGNORE
3 = Acet:YESNOCANCEL
4 = Acet:YESNO
5 = Acet:RETRYCANCEL
Icons
16 = Acet:ICONSTOP
32 = Acet:ICONQUESTION
48 = Acet:ICONWARNING
64 = Acet:ICONINFORMATION
Default buttons
0 = Acet:DEFBUTTON1
256 = Acet:DEFBUTTON2
512 = Acet:DEFBUTTON3
768 = Acet:DEFBUTTON4
Return Values
Returns one of the following values:
1 = Acet:IDOK
2 = Acet:IDCANCEL
3 = Acet:IDABORT
4 = Acet:IDRETRY
5 = Acet:IDIGNORE
6 = Acet:IDYES
7 = Acet:IDNO
8 = Acet:IDCLOSE
9 = Acet:IDHELP
Also another is DOS-LIB has lots of good functions.
My take on yes no look for multi radio buttons.lsp in Cadtutor Downloads.
Edited by BIGAL
Dos lib is not quite easy to install. The multi-radio-buttons lisp is very good, for multiple queries. But the acet-function is easier for yes / no dialog boxes. Thanks for the help with this post.
A not really documented in Multi radio buttons is that the variable BUT holds the button number so a yes = 1 a No = 2. You don't have to use the string value.
(ah:butts but "h"  '("Yes or No" "Yes" "No"))
