Dayananda Posted August 24, 2021 Posted August 24, 2021 (command"pline"""(list 0 0)""W""0""2""(list 10 10)) I tried to draw a pline starting width 0 and end width 2 using above code. But it is not working. Please somebody can give me a correct code. Quote
mhupp Posted August 24, 2021 Posted August 24, 2021 (edited) Close (vl-cmdf "_.Pline" "0,0" "W" "0" "2" "10,10" "") Edit -- This will allow you to pick other points but allow default to 0,0 and 10,10 if you don't pick anything (defun C:Foo (/ PT1 PT2) (or (setq PT1 (getpoint "\nSpecify Base Point: ")) (setq PT1 "0,0")) (or (setq PT2 (getpoint "\nSpecify End Point: ")) (setq PT2 "10,10")) (vl-cmdf "_.Pline" PT1 "W" "0" "2" PT2 "") (princ) ) Edited August 24, 2021 by mhupp 1 Quote
BIGAL Posted August 25, 2021 Posted August 25, 2021 You could use a entmake the difference being the extra codes for width when adding the dxf 10 values. Handy if adding lots of points and fast. (10 280.0 32.0) (40 . 0.0) (41 . 2.0) (42 . 0.0) (91 . 0) 1 Quote
