Repeat to write a DSD file, if find an specific Layoutname
Hi all, below is a snippet of a lisp that writes a custom dsd for the current layout (ctab). So far it works, and creates me a PDF of the current layout.
My problem is that I want to run this section for each layout that contains the layout name *Plan*.
Does anyone have any idea on how I can incorporate this repetition?
      (write-line (strcat "[DWF6Sheet:" (getvar "DWGNAME") "-" (getvar "ctab") "]") file)
      (write-line (strcat "DWG=" (getvar "DWGPREFIX") (getvar "DWGNAME") ".dwg") file)
      (write-line (strcat "Layout=" (getvar "ctab")) file)
      (write-line (strcat "Setup=" ) file)
      (write-line (strcat "OriginalSheetPath=" (getvar "DWGPREFIX") (getvar "DWGNAME") ".dwg") file)
      (write-line (strcat "Has Plot Port=0") file)
      (write-line (strcat "Has3DDWF=0") file)
Edited by Manuel_Kunde
Here's an example:
(setq dwp (getvar 'dwgprefix)
      dwg (getvar 'dwgname)
(foreach lyt (layoutlist)
    (if (wcmatch (strcase lyt t) "*plan*")
        (write-line
            (strcat
                "[DWF6Sheet:" dwg "-" lyt "]"
                "\nDWG=" dwp dwg ".dwg"
                "\nLayout=" lyt
                "\nSetup="
                "\nOriginalSheetPath=" dwp dwg ".dwg"
                "\nHas Plot Port=0"
                "\nHas3DDWF=0"
            file
Thanks Lee, behind the scenes this  was provided to Manuel. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/publish-dsd-file/td-p/1350729
Needs to merge the 2.
(defun c:makedsd (/ file layouts_to_plot NumTabs OldFda )
(setq OldFda (getvar "FILEDIA"))
(setvar "FILEDIA" 0)
;;;(setq layouts_to_plot (dos_multilist "Create Multi-sheet DWF file" "Select drawings" (layoutlist)))
(setq NumTabs (length layouts_to_plot));Number of tabs selected
(setq pathtxt (strcat (getvar "dwgprefix") "newfile.dsd"))
(setq file (open (strcat (getvar "dwgprefix") "newfile.dsd") "w"))
(write-line "[DWF6Version]" file)
(write-line  "Ver=1" file)
(write-line  "[DWF6MinorVersion]" file)
(write-line  "MinorVer=1" file)
(write-line (strcat "[DWF6Sheet:"(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4))"-" (getvar "ctab") "]")file)
(write-line (strcat "DWG=" (getvar "dwgprefix")(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4)) ".dwg")file)
(write-line (strcat "Layout=" (getvar "ctab") )file)
(write-line (strcat "Setup=" )file)
(write-line (strcat "OriginalSheetPath=" (strcat(getvar "dwgprefix")(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4))".dwg") )file)
(write-line (strcat "Has Plot Port=1" )file)
(write-line (strcat "[Target]") file)
(write-line (strcat "Type=1" ) file)
(write-line (strcat "DWF=" (strcat(getvar "dwgprefix")(substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4))".dwf") )file)
(write-line (strcat "OUT="(strcat(getvar "dwgprefix")  )) file)
(write-line (strcat "PWD=" )file)
(close file)
(command "_.delay" 2000)
(command "-Publish" pathtxt )
(setvar "FILEDIA" OldFda)
  (startapp "explorer /e," (getvar "dwgprefix"))
);defun
  • 2 weeks later...
So far the Lisp works fine. However, I noticed that the layouts are not written to the DSD file in series,  left to right, but randomly.
Is it possible to set the order somehow?
The layout list is not randomly, but in alphabetical order. What do you need, to want the layouts from left to right?
Yes that is the problem with the alphabetical order.
I need the order in the DSD as I have the layout tabs arranged, from left to right. In this case they are not alphabetical.
You can use the ActiveX taborder property to sort the layouts by the order in which they appear in the drawing, e.g.:
    (lambda ( / dwg dwp idx lst )
        (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
            (if (wcmatch (strcase (vla-get-name lyt) t) "*plan*")
                (setq lst (cons (vla-get-name     lyt) lst)
                      idx (cons (vla-get-taborder lyt) idx)
        (foreach n (vl-sort-i idx '<)
            (setq lyt (nth n lst))
            (write-line
                (strcat
                    "\nLayout=" lyt
                    "\nSetup="
                    "\nHas Plot Port=0"
                    "\nHas3DDWF=0"
                file
  • Agree 1
I wouldn't have figured it out myself. Thanks a lot!
...taborder...here's another feature I didn't know about. You think you know enough and then you find out you're an ignorant. It's really true: the more you know, the less you know....
Plot based on taborder, ignores layout name. enter 99 auto fills end layout. Cadtutor downloads Plotpdfa3.lsp
