help ...count texts with filter
hello friends :
I want to make a selection in the window of texts , and I want to make a list of texts but grouping the texts that are repeated.
can you help me?
(defun c:test (/ sset grupo)
(setq sset (ssget (list '(0 . "TEXT"))))
(setq grupo (sslength sset))
(princ "\nNumero de textos seleccionados ")
(princ grupo )
If I have a list of values, how can I eliminate the repeated ones?
and generate a new list...
(defun nqf (tuSS / i lista)
(setq cant (sslength tuSS))
;Pasar del SS a una lista de valores
   (setq i 0)
   (repeat (sslength tuSS)
      (setq lista (cons (cdr (assoc 1 (entget (ssname tuSS i)))) lista)
           i (1+ i))
(PRINC lista)
(PRINC)
(defun c:PRU nil (nqf (ssget '((0 . "TEXT")))))
A sample drawing would be a good start.
here example friend
Shutout to @confutatis the code that makes the table was posted by him a few days ago. so if you need it to be bigger maybe he will pop in.
This asks you to Select text. it then makes a list with unique entities. it then goes through that list and makes a selects any text in the current tab and counts them.
then it makes a table or something with all the information.
(defun C:Textcount (/ SS txt txtlst lay laylst layer PT objtable i)
  (if (setq SS (ssget '((0 . "TEXT"))))
      (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
        (if (not (vl-position (setq txt (cdr (assoc 1 (entget e)))) txtlst))
          (setq txtlst (cons txt txtlst))
        (if (not (vl-position (setq lay (cdr (assoc 8 (entget e)))) laylst))
            (setq laylst (cons lay laylst))
            (if (= layer nil)
              (setq layer lay)
              (setq layer (strcat Layer "," lay))
      (setq PT (getpoint "\nSelect point insertion table: ")
            objtable (vla-AddTable (vla-get-modelspace (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-3d-Point PT) (+ 2 (length txtlst)) 2 6 30)
            i 0
      (vla-SetText objtable i 0 "Text Count")
      (vla-SetCellTextHeight objtable i 0 2.40)
      (vla-SetCellAlignment objtable i 0 acMiddleCenter)
      (vla-SetText objtable (setq i (1+ i)) 0 "MARKER")
      (vla-SetCellTextHeight objtable i 0 2.10)
      (vla-SetText objtable i 1 "Counted")
      (vla-SetCellTextHeight objtable i 1 2.10)
      (vla-SetCellAlignment objtable i 1 acMiddleCenter)
      (foreach txt txtlst
        (if (setq SS (ssget "X" (list (cons 0 "TEXT") (cons 1 txt) (cons 410 (getvar 'ctab)) (cons 8 layer))))
            (vla-SetText objtable (setq i (1+ i)) 0 txt)
            (vla-SetText objtable i 1 (itoa (sslength ss)))
*edit
this only looks for text on the "COTAS" layer if this limits your selection delete "(cons 8 "COTAS")" out of the lisp
Updated the code to scrape the layer name from the selected text and only search on that layer for text.
Edited by mhupp
notes
Pretty sure I have some code from PBE that uses a mapcar function to to count the common items in a list, like ((x 1)(y 1)(x 1)(x 1)(y 1)) becomes ((x 3)(y 2) a easier way when making the table I use insert rows for the data as the list size can vary. I will try to find it.
This is not it but something close.
; Make a count of common items
; By AlanH Aug 2021
(defun my-count (a L)
  (cond
   ((null L) 0)
   ((equal a (car L)) (+ 1 (my-count a (cdr L))))
   (t (my-count a (cdr L))))
; By Gile
(defun remove_doubles (lst)
  (if lst
    (cons (car lst) (remove_doubles (vl-remove (car lst) lst)))
(defun c:test ( / ss lst lt2 lst3 txt )
(setq ss (ssget (list (cons 0 "TEXT"))))
(if (= ss nil)
(alert "no text picked")
  (setq lst '() lst3 '())
    (setq txt (cdr (assoc 1 (entget (ssname ss (setq x (1- x)))))))
    (setq lst (cons txt lst))
  (setq lst2 (remove_doubles lst))
  (foreach val lst2
    (setq cnt (my-count val lst))
    (setq lst3 (cons (list val cnt) lst3))
(princ "\n")
(princ lst3) ; do table now
(c:test)
Edited by BIGAL
; By AlanH Aug 2021
  (cond
   ((null L) 0)
; By Gile
  (if lst
(if (= ss nil)
  (foreach val lst2
(princ "\n")
(c:test)
you can make each created data copy it to a specific text?
for example:
selected texts
L-6122-009
L-6122-008
L-6122-008
L-6122-008
list obtained   ((L-6122-009 1) (L-6122-008 3))
now this information can be transferred to existing texts
pick text1 ------>   L-6122-009
pick text2 ------>   1
pick text3 ------>   L-6122-008
pick text4 ------>   4
successively
YES
But looking at your sample its better to make a table of the answer. Just select text then pick point for table.
; https://www.cadtutor.net/forum/topic/73550-help-count-texts-with-filter/
; example of creating a table using passed variables
; By Alan H July 2017
; By AlanH Aug 2021 info@alanh.com.au
  (cond
   ((null L) 0)
; By Gile
  (if lst
(if (= ss nil)
(setq howlong 0)
(foreach val lst2
	(setq howlong (strlen (car (last lst3))))
	(if (> howlong howmany)(setq howmany howlong))
(setq txtht 45)
(setq numcolumns 2 numrows (+ 2 (length lst3)) txtsz (* txtht 2.0) colwidth (* howlong 2.0 txtht))
(setq sp (vlax-3d-point (getpoint "Pick top left")))
(setq doc  (vla-get-activedocument (vlax-get-acad-object) ))
(if (= (vla-get-activespace doc) 0)
(setq  curspc (vla-get-paperspace doc))
(setq curspc (vla-get-modelspace doc))
(setq rowheight (* 3.0 txtht))
(setq objtable (vla-addtable curspc sp numrows numcolumns rowheight colwidth))
(vla-setcolumnwidth objtable 1 (* 3 txtht))
(vla-SetTextHeight Objtable (+ acDataRow acTitleRow acHeaderRow) txtht)
(setq n 2)
(vla-setcolumnwidth objtable 0 colwidth)
(vla-setcolumnwidth objtable 1 400)
(vla-settext objtable 0 0 "TABLE title")
(vla-SetText Objtable 1 0 "Mark")
(vla-SetText Objtable 1 1 "Count")
(setq x 0)
(repeat (length lst3)
(setq val (nth (- n 2) lst3))
(vla-SetText Objtable n 0 (car val))
(vla-SetText Objtable n 1 (cadr val))
(setq n (1+ n))
(vla-SetAlignment objtable acDataRow acMiddleCenter)
(c:test)
3 hours ago, BIGAL said:
YES
  (cond
   ((null L) 0)
; By Gile
  (if lst
(if (= ss nil)
(setq howlong 0)
(foreach val lst2
(setq txtht 45)
(setq n 2)
(setq x 0)
(setq n (1+ n))
(c:test)
I understand that a table is better, but I need to pass the information obtained in the list to some existing texts
Thanks to your code I was able to extract the values as I need them, thank you very much
