add if not in list
mhupp
Is their a better way to filter unique block names?
  (if (setq SS (ssget '((0 . "INSERT"))))
      (setq Path (getvar "DWGPREFIX"))
      (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
        (if (not (vl-position (setq blkname (cdr (assoc 2 (entget e)))) blklst))
          (setq blklst (cons blkname blklst))
      (foreach blkname blklst
Not that I can think of... I think that's the most efficient. I don't know if this is better:
(if (setq pth (getvar 'dwgprefix) ss (ssget '((0 . "INSERT"))))
	(if (not (vl-position (setq i (1- i) nm (cdr (assoc 2 (entget (ssname ss i))))) lst))
	        ;; do your thing
	        (setq lst (cons nm lst))
Edited by Jonathan Handojo
  • Thanks 1
Another approach. It is not tested if the blocks are referred in the drawing, but only if they are defined!
(vlax-for el (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
 (setq $name (vla-get-name el))
 (if (/= (substr $name 1 1) "*") ;;Filter out anonymous blocks
  (setq LS_BLOCK_NAMES (cons $name LS_BLOCK_NAMES))
