Issue with "FILLET" command in AutoLisp
coolxpert
Hi, I'm experiencing an unusual issue. I routinely use (command "FILLET" fp1 fp2) to fillet centrelines, in code which generates pipe drawings. Points fp1 & fp2 are derived from the insertion point of elbow blocks. This has worked without problems for years. I recently copied some of the code into a newer program & it doesn't work! Prompts for the points appear on the command line as if I'd invoked fillet from a menu. Strangely if I use (getpoint) to set temporary point variables say p1 p2 & then type (command "FILLET" p1 p2) <ret> it works as it should. Also if I put a temporary (command "LINE" fp1 fp2 "") in the code it draws it correctly before the auto fillet fails. This has taken over my life - does anyone have any suggestions?
Can you post a piece of the drawing and the offending code, please?
Still works in the old program? Sounds like you didn't copy everything from the old program it needs. but like my good buddy @confutatis has said we cant really do anything with out the a drawing and code in question.
As you're a new member you may not be able to attach drawings yet but clicking the <> in the toolbar at the top of a new post or reply would allow you to add the old & new code to debug what went wrong.
Lots of file sharing sites out there that would allow you to post a link to a drawing with a before and after of what you want the lisp to do: https://blog.bit.ai/free-file-sharing-sites/
  • 2 weeks later...
Thanks for the responses. I've attached part of a drawing and here's a piece of the offending code - I hope it doesn't offend too much. The drawing shows
some elbows which have been inserted during the auto pipe draw. My program lets me set the diameter etc. then I just draw the pipe route as a polyline. When the (pipeup) function is invoked I pick the centreline and then I'm prompted at 90° changes for which elbow I want, like [E]lbow, [A]way or [T]owards. If I pick [E] the centreline is filleted.
There's another routine which allows me to change the block by clicking it, it then cycles through the defined elbow blocks until I decide which one I want. The problem arises when I change a towards or away elbow to a simple side-on [E]lbow - it should fillet but it doesn't. Even when I stamp my feet and use foul language. This exerpt is from the part that works but the way in which the fillet pick points are derived is the same in the code used to modify elbows. I know the pick points are in the right place because I can draw a temporary line between them.
(setq fname (strcat "N" (car #erad) f (car eins)))         ; giving ex NSE90
  (if (= f "E") (progn    (setq fp1 (polar ipt (dtor(car a )) #pdia))
                          (setq fp2 (polar ipt (dtor(cadr a)) #pdia))
              			  ( if (OR (= (car #erad) "S")  (= (car #erad) "P"))
           					 (setvar "FILLETRAD" #pdia)
           					 (setvar "FILLETRAD" (* #pdia 1.5))
        (command "FILLET" fp1 fp2 )
  (command "INSERT" fname ipt isc isc (cadr eins))
Pipe_Example.dwg
This isn't enough code to help you. it has several unknown variables #erad, eins, f, ipt, dtor #pdia and a unknown function dtor
Like mhupp need a before and after in the dwg and label points fp1 and fp2
  • 2 weeks later...
Thanks everyone for having a look. It's probably not worth expending further effort on. I'll send an update when I solve it. Some day when I've finished monitoring the progress of all drying paint on the premises, I'll return to this issue.
