lamensterms Posted August 5, 2021 Share Posted August 5, 2021 (edited) Hey guys, Just wondering if anyone knows of a tool or routine that will generate a basic part list of selected 3DSOLIDs. Kinda similar to: Post #2 here: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/3d-solid-dimensions/m-p/2571580/highlight/true#M282655 Post #3 here: https://www.cadtutor.net/forum/topic/16993-3d-objects-volume-lisp-required/?do=findComment&comment=139394 These above routines do pretty much what I'm hoping for, but will only work on a single selected item. I'd like to be able to execute this routine on multiple items, with output as either ACAD table, or .TXT or .CSV (then I can format in Excel). The application is to generate a quick BOM for selected 3DSOLID elements. My new job uses a few subbies that use Inventor for steel detailing. I've got no experience with Inventor, but one of it's greatest shortcomings in this field is their BOM export relies on manual data entry for each part. To my knowledge, Inventor is incapable of automatically assigning dimension properties to parts, so the BOMs that our subbies are giving us are only showing very basic data, for example - part number & qty, but no part dimensions. Critical fields are: QTY Length Width Height Thanks for any help guys! Edited August 5, 2021 by lamensterms Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 6, 2021 Share Posted August 6, 2021 Would massprop do Mass: 28716335.8463 Volume: 28716335.8463 Bounding box: X: 8385.1459 -- 9240.2806 Y: 2515.2082 -- 3370.3430 Z: 0.0000 -- 50.0000 You write the answer to a file then reread it so read lines 4,5,6 = length width height bit rough but closer than nothing. 1 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 6, 2021 Share Posted August 6, 2021 DataExtraction table is probably as close as you will get out of the box in AutoCad, I sense you are missing ProSteel as you write this. I will play around with it a bit, and see what information can be extracted. I use DX tables just to itemize names and counts of items in different Modules, but it is highly configurable. I will take a look at available parametrics for display on their lists. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 6, 2021 Share Posted August 6, 2021 I was pretty surprised by the conspicuous inability to shed any light on this using Data Extraction. It would just tell me How many and that they were 3D Solids, all kinds of other stuff could be accessed, but essentially having little to nothing to do with a BOM, nor even Steel for that matter. Not for lack of trying, hopefully one of The Lisperati will be able to shed some light. Quote Link to comment Share on other sites More sharing options...
lamensterms Posted August 10, 2021 Author Share Posted August 10, 2021 Thanks for the replies guys. @BIGAL - Thanks for the tip on MASSPROP, that could lead to a solution. Would require a bit of processing for the output data. @Dadgad - Yes sorely missing ProSteel for this task. Inventor is definitely not the right tool for the job Quote Link to comment Share on other sites More sharing options...
SEANT Posted August 10, 2021 Share Posted August 10, 2021 Are these solids typical steel sections? The AutoCAD APIs can process straight extrusions fairly easily - extrusions with subsequent Booleans or Slice operations become more of a handful. Perhaps post and example drawing, if possible. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 10, 2021 Share Posted August 10, 2021 Inventor should do what you want. Sounds like the Inventor guys need training, if it's an iProperty, it can be in the BOM, AFAIK. Unless they have messed that up since I last used Inventor years ago. Quote Link to comment Share on other sites More sharing options...
maratovich Posted August 10, 2021 Share Posted August 10, 2021 Try to use this - 3DSolidBox I hope it helps you. Quote Link to comment Share on other sites More sharing options...
