jyoung98 Posted July 30, 2021 Posted July 30, 2021 Hi, I'm working on a LISP that in part needs to grab the filename (without extension) for a command - I managed to do this using 'vl-filename-base' but since it needs to run in acoreconsole it can't use anything from the VL Library. Is there any way to either remove ".dwg" or remove the last 4 characters from a string in only vanilla LISP? Here's what I've got so far (defun C:PlotToLocation (/ filename) (vl-load-com) (setvar "cmdecho" 0) (setq filename (vl-filename-base (getvar 'dwgname))) (setq filename (strcat "A:\\X\\Y\\" (vl-filename-base (getvar 'dwgname))".pdf")) This sets the filename to "A:\X\Y\filename.pdf" I can currently get "A:\X\Y\filename.dwg.pdf" but since the PDFs have to follow a naming standard, I need a way to remove the ".dwg". Quote
BIGAL Posted August 2, 2021 Posted August 2, 2021 (edited) Look into Strlen and Substr with those 2 lisp commands can do what you want. (setq dwgn (getvar 'dwgname)) (setq len (strlen dwgn)) your turn substr https://www.afralisp.net/reference/autolisp-functions.php Edited August 2, 2021 by BIGAL 1 Quote
ronjonp Posted August 2, 2021 Posted August 2, 2021 50 minutes ago, rlx said: (cadr (fnsplitl (getvar 'dwgname))) HAHAHA ... cross posted at Adesk forum last Friday. 1 Quote
jyoung98 Posted August 5, 2021 Author Posted August 5, 2021 Awesome, thanks everyone. Ended up going with (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)) Quote
