I am looking for a Lisp Routine that will select the Raster Image in my Drawing and place it on Layer 0. I have tried different approaches but am unable to figure it out. Can anyone help?
Thanks.
Unable to figure it out Why not on layer "Image", have a look at (setq ss (ssget "X" '((0 . "IMAGE")))) you can then either entmod (assoc 8 or use (vla-put-layer I dont use often maybe even (setpropertyvalue ent "layer" "IMAGE")
Edited by BIGAL
I understand your first code statement of (setq ss (ssget "X" '((0. "IMAGE")))) but not sure about he rest. When the fist statement creates the list how would I separate out just the IMAGE entity from that list and use it within the Command "Change".
Basically what I want to do is this,
(command "change" Image "" "p" "la" "0" "") - using the list to call out the IMAGE through properties then layer and assigning it to layer 0. This is what I would like it to do.
Try this .. will put all images in the drawing on layer 0 ( unless on a locked layer )
(defun c:foo (/ s)
  (if (setq s (ssget "_X" '((0 . "IMAGE"))))
    (foreach e (mapcar 'cadr (ssnamex s)) (entmod (append (entget e) '((8 . "0")))))
Nice Ronjonp
old fashioned (command "change" ss "" "p" "la" "0" "")
