can anyone help me to create a lisp to connect all blocks with arcs.
A similar request was made for pline s as arcs, a few days ago may have been at Forums/autodesk. On iPad can not post code.
Dear Bigal
pls share me by email :
EMAIL REMOVED
Edited by CADTutor
Please avoid using your email in posts, it will generate spam.
Dear mhupp
thank you..
I saw so complicated things at there..
and difficult to understand.
i thing your asking about this
;; CAB 05.13.09
;;  Draw Electric Wire
(defun c:ew (/ ew_layer p1 p2 msg)
 (setq ew_layer "Wire")      ; layer name
 (defun draw-ew (p4 p1 lay / p2 p3)
   (setq p2 (polar p1 (- (angle p1 p4) (/ pi ) 57.40259411)
         p3 (polar p4 (+ (angle p4 p1) (/ pi ) 57.40259411)
   (entmakex
     (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline")
           (cons 8 lay)
           (cons 90 4)
           '(70 . 0)         ; 1 for closed 0 overwise
           (cons 10 (trans p1 1 0)) '(40 . 0.0) '(41 . 0.0) '(42 . 0.198912)
           (cons 10 (trans p2 1 0)) '(40 . 0.0) '(41 . 0.0) '(42 . 0.0)
           (cons 10 (trans p3 1 0)) '(40 . 0.0) '(41 . 0.0) '(42 . 0.198913)
           (cons 10 (trans p4 1 0)) '(40 . 0.0) '(41 . 0.0) '(42 . 0.0)
           '(210 0.0 0.0 1.0)
 (and
   (setq p1 (getpoint "\nPick start point (Draw clockwise"))
   (setq msg "\nPick next point clockwise.")
   (while (setq p2 (getpoint p1 msg))
     (draw-ew p1 p2 ew_layer)
     (setq p1 p2)
(prompt "\nElectric Wire loaded, Enter EW to run.")
refer,
