Henryjohn Posted February 10, 2009 Posted February 10, 2009 Sorry if this has been all ready been dealt with but I couldn't find anything specific when I did a search. Using AC2008 Would like to be able to draw a box (boundary) over a drawing that consists of lines, polylines etc. and be able to delete everything outside the box. That means the polylines and lines etc. would be broken at the boundary and deleted The drawings are of towns, which show all the house boundrys, roads and main service infrastructure (water, sewer, etc.) but I only need to work on 1 or 2 streets not the whole town. I know i can trim and extend and break the lines but it would be so cool to be able to do it in one comand Thanks in Advance HenryJohn Quote
CarlB Posted February 10, 2009 Posted February 10, 2009 Try the Express Tools command "extrim", should handle that. Quote
Lee Mac Posted February 10, 2009 Posted February 10, 2009 Blimey... never used extrim before - absolutely fantastic command Quote
lpseifert Posted February 10, 2009 Posted February 10, 2009 You might like this one... http://www.theswamp.org/index.php?topic=24646.0 Quote
Henryjohn Posted February 11, 2009 Author Posted February 11, 2009 not bad, but when I run extrim not all of the lines are deleted only some of them. Am I doing something wrong??? Quote
lpseifert Posted February 11, 2009 Posted February 11, 2009 If the object you're trying to trim isn't a continuous linetype, and a 'space' happens to land on the trim boundary, it won't trim. Also, I find that the results of the extrim command are iffy. Quote
CarlB Posted February 11, 2009 Posted February 11, 2009 You can set ltscale real small before running it to hopefullay avoid most "broken line" problems with it. An inconvenience, but for infrequent use, BTN. Quote
JohnM Posted February 11, 2009 Posted February 11, 2009 give this a try. it needs some error trapping to make it solid but you can get the idea. i took the front end of the express tools extended trim program and made it accept 2 arguments 1- entity name of rectangel and the corner point of the rectangle. then it will use the rest of the express tool extend trim program, so therefore this will only work if you have expresstools installed. load it up and type test on the command line (defun c:test (/ rect llc urc ) (setq rect(car(entsel"\n Select Rectangle or Closed Polyline")));_get rectangle (vla-GetBoundingBox (vlax-ename->vla-object rect) 'minpt 'maxpt);_check for heigth /width (setq llc (vlax-safearray->list minpt) urc (vlax-safearray->list maxpt) );_setq (extrim2 rect llc);_call to extended trim pass ent name and point (command "erase" "all" "r" "w" urc llc "");_erase everything outside the rectangle (princ) );_defun ;;; borrow from expresstools extended trim code and make it work for this (defun extrim2 (ag1 ag2 / na e1 p1 redraw_it lst n ) (acet-error-init (list (list "cmdecho" 0 "highlight" 0 "regenmode" 1 "osmode" 0 "ucsicon" 0 "offsetdist" 0 "attreq" 0 "plinewid" 0 "plinetype" 1 "gridmode" 0 "celtype" "CONTINUOUS" "ucsfollow" 0 "limcheck" 0 ) T ;flag. True means use undo for error clean up. '(if redraw_it (redraw na 4)) );list );acet-error-init (setq na ag1) (if na (progn (setq e1 (entget na));;setq (if (or (equal "TEXT" (cdr (assoc 0 e1))) (equal "MTEXT" (cdr (assoc 0 e1))) (equal "ATTDEF" (cdr (assoc 0 e1))) (equal "IMAGE" (cdr (assoc 0 e1))) (equal "INSERT" (cdr (assoc 0 e1))) (equal "SOLID" (cdr (assoc 0 e1))) (equal "3DFACE" (cdr (assoc 0 e1))) (equal "TRACE" (cdr (assoc 0 e1))) );or (progn (setq lst (acet-geom-object-point-list na nil)) (setq n 0) (command "_.pline") (repeat (length lst) (command (nth n lst)) (setq n (+ n 1));setq );repeat (if (not (equal (car lst) (last lst) 0.0000001)) (command "_cl") (command "") );if (setq na (entlast) e1 na );setq );progn then draw a temp pline to be the cutting edge. (setq e1 nil) );if (redraw na 3) (setq redraw_it T) (setq p1 ag2) (redraw na 4) (setq redraw_it nil) (if p1 (etrim na p1));if (if e1 (progn (if (setq p1 (acet-layer-locked (getvar "clayer"))) (command "_.layer" "_un" (getvar "clayer") "") );if (entdel e1) (if p1 (command "_.layer" "_lock" (getvar "clayer") "") );if );progn then );if );progn );if (acet-error-restore) (princ) );defun c:extrim Quote
