I am working on a project for creating chamfers in an isometric view, when I attempt to chamfer the lines it gives an error" Lines are parallel" How do I get around this, is there a certain setting?
Thank You!
  • 1 month later...
Does the command work in orthographic view? Probably not. The lines you chamfer must inters
ct somewhere. The probably do not. (out of plane as well)
