Hi i am using this lisp code to write texts in specific layer. The problem is when i write the text in command line an press space create double space between the words . Is any way to fix it. I want one space between the words. Thanks
My keybord bug ..... Sory
Edited by prodromosm
Can you show us an example of what are you doing and the results, to see if anyone can help you.
  • Funny 1
The code works fine, but the space bar on my keybord had problem.
Thanks
