muck Posted July 20, 2021 Share Posted July 20, 2021 I scanned in image of a house with a copier and attached in an AutoCAD drawing using pdf attach. I super imposed my drawing on the image hopping to print a house picture with my drawing on top of it. Only my drawing will print. Not the image of the house. Is there a way to print the image attached pdf image of the house with my drawing out of AutoCAD? I am using AutoCAD LT. Thank you, Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 21, 2021 Share Posted July 21, 2021 (edited) Not sure what your doing wrong this is what you are talking about, but Autocad or Bricscad. Only way for any one to check would be to post a dwg and a pdf. Edited July 21, 2021 by BIGAL 2 Quote Link to comment Share on other sites More sharing options...
tombu Posted July 21, 2021 Share Posted July 21, 2021 Did you use the Attach command or did you paste it in as OLE? It should have worked using the Attach command. https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-928B7980-2174-4F1E-8059-9F1B1884E7C8 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 22, 2021 Share Posted July 22, 2021 Does it show in plot preview? Can you post an example drawing? Can you post your plot settings? Maybe run this ......... Some OLE objects or embedded images do not plot from AutoCAD | AutoCAD | Autodesk Knowledge Network Have you tried using a different image type? Quote Link to comment Share on other sites More sharing options...
muck Posted July 27, 2021 Author Share Posted July 27, 2021 I used the pdf attach command to place the pdf image in the drawing. The drawing image did not show up in the plot preview. Thank you, I Quote Link to comment Share on other sites More sharing options...
muck Posted July 27, 2021 Author Share Posted July 27, 2021 I used the windows 10 snip-it to reinsert the pdf image. That allow me to print the picture. Thank you, Quote Link to comment Share on other sites More sharing options...
