lamensterms Posted July 19, 2021 Share Posted July 19, 2021 Hi, Please see images below. I have found that ACAD 2017 will plot PDFs (using 'DWG to PDF.pc3') but will not represent isometric circles & isometric text correctly. Same block and same font shown in both images. - The correct picture was plotted using 'DWG to PDF.pc3' on ACAD2015, Windows 8 64 bit. - The incorrect picture was plotted using 'DWG to PDF.pc3' in ACAD2017, Windows 10 64 bit. Is it possible to fix this? Thanks for any help Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 20, 2021 Share Posted July 20, 2021 Bugs for 2017 may be very hard as we are now at 2022 that is 5 versions later, maybe a different pc3 will work. Try say a Adobe or another create PDF software, Microsoft pdf ? Quote Link to comment Share on other sites More sharing options...
lamensterms Posted July 20, 2021 Author Share Posted July 20, 2021 (edited) Thanks BIGAL. I totally understand I'm a few years behind the current versions haha... just hoping someone has encountered and overcome this issue before me. I'll have a play around with alternative PDF writers. But I do favour 'DWG to PDF' as it works very well with my plotting LISP routine... output file naming support in particular. Edited July 20, 2021 by lamensterms Quote Link to comment Share on other sites More sharing options...
ammobake Posted July 23, 2021 Share Posted July 23, 2021 Might it be possible to use a current version of the Pc3 file (DWG to PDF) in Autocad 2017? But I have seen wierd quirks like that in the older version of the pc3 file. -ChriS Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 23, 2021 Share Posted July 23, 2021 Try plotting with the latest DWG TrueView. If that doesn't work, something is amiss on your computer and not AutoCAD 2017. You should try to post the file here as well. 2 Quote Link to comment Share on other sites More sharing options...
lamensterms Posted July 26, 2021 Author Share Posted July 26, 2021 Thanks for the replies guys. @ammobake I've tried pointing ACAD to a more recent PC3 (from TrueView 2021) - still get the same results when plotting from ACAD2017. I think the PC3 file still points to the .HDI driver that is possibly the source of the issue. @SLW210 I've tested plotting from TrueView 2021, and it plots correctly. My understanding is that it's the .HDI that has the issue (not the PC3). I'm not sure how to control which .HDI the .PC3 points to - seems to use whichever version that was shipped with the ACAD version (or maybe whichever version was launched most recently?). If there is a way force my PC3 to use an alternative HDI driver, I expect that will fix the issue. I've attached some sample files, showing varying results.... I continue to scratch my head Drawing1 (12.05) (12.17).dwg Drawing1 (12.05)-Model.pdf Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 26, 2021 Share Posted July 26, 2021 Can you replace the 2017 HDI with the newer one from DWG TrueView? Do you have all updates? Perhaps it's time to discuss a newer AutoCAD version. Quote Link to comment Share on other sites More sharing options...
lamensterms Posted July 27, 2021 Author Share Posted July 27, 2021 I can replace it - but then I get a Heidi error for driver mismatch... which looks like this: There are some other support files that I can try replace and rename, but haven't got around to testing that just yet. Unfortunately updating ACAD isn't an option at the moment... I used ProSteel with ACAD, and the version of ProSteel I use is only compatible up to ACAD2017. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 27, 2021 Share Posted July 27, 2021 Maybe a third party PDF plotter or just plot PDFs with DWG Trueview. I cannot think of anything else unless Autodesk has a fix, though I doubt they would bother with AutoCAD 2017, but doesn't hurt to ask. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 28, 2021 Share Posted July 28, 2021 Like SLW210 there are many PDF writers Microsoft, Adobe, Cutepdf, Bluebeam to mention a few. Quote Link to comment Share on other sites More sharing options...
