just for understanding
Ajmal
I just started to learn lisp and mostly am copy-pasting and checking one by one.  I do not have a programing background or anything like that so please help me to understand.
Last time I make something I need. It was successfully I finished.
Please tell me if there is any mistake or your suggestion
And if you can put your way for the same task that may be I can understand very well on new things
(while
      (setq entldr nil enttxt nil)
    (if
      (setq sel(LM:ssget "\nSelect Text & leader: "
			 (list "_:L"
			       (list
				 '(000 . "TEXT,MTEXT,LEADER")
				 (if (= 1 (getvar 'cvport))
				   (cons 410 (getvar 'ctab))
				   '(410 . "Model")
	(cond
	  (	(< 2 (sslength sel))
	   	(princ "\nThe selection have more than 2 object")
	  (	(= 1 (sslength sel))
		  (cond
		    (	(not (wcmatch(cdr (assoc 0(entget(ssname sel 0))))"TEXT,MTEXT"))
		     	(princ "\nThe selection don't have text")
		    (	(not (wcmatch(cdr (assoc 0(entget(ssname sel 0))))"LEADER"))
		     	(princ "\nThe selection don't have leader")
	  (	(= 2 (sslength sel))
		  (repeat (setq i (sslength sel))
		    (or (not (entget (setq ent (ssname sel (setq i (1- i))))))
		    (if
		      (not (wcmatch(cdr (assoc 0(entget ent)))"TEXT,MTEXT"))
		      (setq entldr ent)
		      (setq enttxt ent)))
		  (cond
		    (	(= entldr nil)
		     	(princ "\nThe selection have multiple text")
		    (	(= enttxt nil)
	    		(princ "\nThe selection have multiple leader")
Maybe you could explain a little more on what your trying to do. but here are my suggestions so far.
while & cond do not need progn to run multiple lines of code.
you aren't defining anything with while so i removed it. think of it as loop while conditions are met.
iv stoped using (ssname sel (setq i (1- i)) to step thorougth the selection sets and use foreach with ssnamex
also defined local variables so
1. they arn't global variables
2. they are cleared or nil after the lisp runs.
use (princ) at the end or you will return the last thing outputted again.
The selection have more than 2 object"\nThe selection have more than 2 object"
Think of all possibility that you can run into when using conditions.
your ((= 2 (sslength sel)) would trigger if you had two text or a text and a leader.
(defun C:foo (/ ldr txt sel)
  (setq ldr 0 txt 0) ;better tracking of selection with integers
  (if (setq sel (ssget "_:L" '((0 . "TEXT,MTEXT,LEADER") (cons 410 (getvar 'ctab)))))
      (cond
        ((< 2 (sslength sel))
            (prompt (strcat "\nTheir are " (itoa (sslength sel)) " entitys in this selection"))
        )   ;more then 2 is vage use the actual number
        ((= 1 (sslength sel))
          (cond
            ((not (wcmatch (cdr (assoc 0 (entget (ssname sel 0)))) "TEXT,MTEXT"))
            ((not (wcmatch (cdr (assoc 0 (entget (ssname sel 0)))) "LEADER"))
          (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex sel)))
            (if (wcmatch (cdr (assoc 0 (entget ent))) "TEXT,MTEXT")
             (setq txt (1+ txt))
             (setq ldr (1+ ldr))
          (cond
            ((= ldr 2) ;Both entitys have to be text for this to trigger.
                (princ "\nThe selection have 2 text")
            ((= txt 2) ;Both entitys have to be leaders for this to trigger.
                (princ "\nThe selection have 2 leader")
            ((= txt 1) (= ldr 1)
                (princ "\nThe selection is 1 leader and 1 text")
  (prompt "\nNothing selected")
Edited by mhupp
7 hours ago, devitg said:
Hi Ajmal , please clear what is the SAME TASK  to do
My task is to make a selection set with 2 items, and extract that item and entget the item, but
Which means
                Ssget the item text and leader
                Check the selection set contain only 2 items from that should be only text and leader
                And from the selection set  extract the item end endget the item
Here is the correct task
I got this code from the forum. And I need to add something from me to be useful for me
(defun rh:gbbw (obj / ll ur lst wt)
  (if (and obj (= (type obj) 'ENAME))  (setq obj (vlax-ename->vla-object obj)))
  (vlax-invoke-method obj 'getboundingbox 'll 'ur)
  (setq lst (mapcar 'vlax-safearray->list (list ll ur)) wt (mapcar '(lambda (x y) (- x y)) (cadr lst) (car lst)))
  wt
);end_defun
(defun rh:z22pi (ar) (cond ( (equal ar (* pi 2.0) 1.0e-10) 0.0) ( (< -1.0e-16 ar (* pi 2.0)) ar) (t (rh:z22pi (rem (+ ar (* pi 2)) (* pi 2))))))
(vl-load-com)
(defun c:let ( / sel ent el w obj nobj tang ipt lel lent lst lang a b ept)
  (while (setq sel (entsel "\nSelect Leader Text : "))
    (setq el (entget (setq ent (car sel))) w nil nobj nil)
    (cond ( (= (cdr (assoc 0 el)) "TEXT")
            (setq obj (vlax-ename->vla-object ent) tang (rh:z22pi (cdr (assoc 50 el))) ipt (cdr (assoc 10 el)))
            (if (not (zerop tang)) (vlax-put obj 'rotation 0))
            (setq w (rh:gbbw obj))
            (if (not (zerop tang)) (vlax-put obj 'rotation tang))
          ( (= (cdr (assoc 0 el)) "MTEXT")
                  nobj (vla-copy obj)
            );end_setq
            (vl-cmdf "explode" (vlax-vla-object->ename nobj) "")
            (setq el (entget (setq ent (entlast))) ipt (cdr (assoc 10 el)) nobj (vlax-ename->vla-object ent))
            (if (not (zerop tang)) (vlax-put nobj 'rotation 0))
            (setq w (rh:gbbw nobj))
            (vla-delete nobj)
    );end_cond
    (cond (w
            (setq w (car w)
                  lel (entget (setq lent (car (entsel "\nSelect Leader : "))))
            );end_setq
            (cond ( (= (cdr (assoc 0 lel)) "LEADER")
                    (setq obj (vlax-ename->vla-object lent)
                          lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) lel))
                          lang (rh:z22pi (angle (setq a (nth (- (length lst) 2) lst)) (setq b (last lst))))
                    );end_setq
                    (if (equal lang tang 1.0e-4) (setq ept (polar ipt tang w)) (setq ept ipt))
                    (setq ept (inters a b ept (polar ept (+ tang (* pi 0.5)) 5.0) nil)
                          lst (reverse (cons ept (cdr (reverse lst))))
                    (vlax-put obj 'coordinates (apply 'append lst))
            );end_cond
    );end_cond
  );end_while
);end_defun
And I had some issues and I try to solve and  I get the answer from the another topic
Here is the topic
so it was successfully finished
Then I had a new idea think it not with only this topic. I need to understand more about the lisp so I created this topic.
I have done what I need. but I need to understand the things is more clear. what I did is copy-paste and checking one by one.
  wt
(vl-load-com)
(defun c:let(/ l sslgn sel i entldr enttxt)
  (while
    (if
			 (list "_:L"
			       (list
				   '(410 . "Model")
	(cond
		  (cond
		    (if
		      (setq entldr ent)
		      (setq enttxt ent)))
		  (cond
		    (	(= entldr nil)
		    (	(= enttxt nil)
      (setq el (entget enttxt) w nil nobj nil)
            (setq obj (vlax-ename->vla-object enttxt) tang (rh:z22pi (cdr (assoc 50 el))) ipt (cdr (assoc 10 el)))
                  nobj (vla-copy obj)
		  ss   (ssadd)
            );end_setq
	   (setq en (entlast))
            (vl-cmdf "._explode" (vlax-vla-object->ename nobj))
            (setq el (entget (setq enttxt (entlast)))
		  nobj (vlax-ename->vla-object enttxt))
	   (while (setq en (entnext en))
              (if (not (wcmatch (cdr (assoc 0 (entget en))) "ATTRIB,VERTEX,SEQEND"))(ssadd en ss))
            (repeat (setq ssi (sslength ss))
	      (or (not(entget (setq ssent (ssname ss (setq ssi (1- ssi)))))))
		  (vla-delete (vlax-ename->vla-object ssent))
    (cond (w
            (setq w (car w)
                  lel (entget entldr)
            );end_setq
                    (setq obj (vlax-ename->vla-object entldr)
                    );end_setq
            );end_cond
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
I need to know not only to clear the topic. what are my mistakes and what I should do or not
these websites are good for tutorials to help you understand whats going on.
https://www.afralisp.net/autolisp/
http://www.lee-mac.com/tutorials.html
https://www.cadtutor.net/tutorials/autolisp/quick-start.php
they have step by step instructions with clear examples.
also doesn't hurt to have a lisp dictionary for things you run across that might not understand whats its doing.
https://documentation.help/AutoLISP-Functions/WSfacf1429558a55de1a7524c1004e616f8b-5913.htm
Edited by mhupp
made links clickable
