Batch printing with ctab system variable
I'm trying to batch print several paper space layouts in one PDF using MText/insert Field/SystemVariable/ctab.
I want each unique tab name to print on each page
Whatever page is active when I save is printed on all pages of the PDF.
Doesn't matter if I put the MText on the model page or the layout tab.
Is this possible without a script or coding?
Using AutoCad LT -2022
Edited by Steve221
Have you looked at "Publish" having LT makes it hard to program an answer.
Publish from LT
Edited by BIGAL
Thanks, but same result.
The ctab system variable is the same on each tab when printed or published.
Found the answer...
Needed to go to OPTIONS/USER PREFERENCES/FIELDS/FIELD UPDATE SETTINGS.../ and check PLOT
