I was under the impression that if you had an IF statement, the code following was conditional
(if (setq A1 (ssget "_X" '((0 . "DIMENSION"))))
(command "change" A1 "" "P" "La" "Dim" "co" "bylayer"  "lw" "bylayer" "lt" "bylayer"  ""))
In this instance, shouldn't it check to see if there are any DIMENSIONs and if so proceed, if not exit?
This is part of a routine I am working on and it works if there are dimensions found but if no dimensions are present I get an error.
Unknown command "P".  Press F1 for help.
Unknown command "LA".  Press F1 for help.
*Invalid selection*
Expects a point or Last
*Cancel*
Select continued dimension: *Cancel*
Can someone please clarify.
Definitely willing to admit that my understanding is limited...
My goal is if not found, exit.
(if (setq A1 (ssget "_X" '((0 . "DIMENSION"))));;; if A1 exists...
 (command "change" A1 "" "P" "La" "Dim" "co" "bylayer"  "lw" "bylayer" "lt" "bylayer"  "");;; true condition
 (vl-exit-with-error (alert "No dimension!"));;; <-- if no dimension, false condition
In the if function, if the condition is true everything inside the first progn is valid, otherwise the second (if there is only one line of programming the progn instruction is not needed). You did not specify the false condition, so you got the error message.
Edited by confutatis
You dont need to have a false statement for an if statement to work in BricsCAD. This might be an SolidWorks issue. both of these work for me with out errors.
This also is a good write up.
Quote
(if (only one predicate)  ;must return T, even if it is a double negative
(then do something)      ;if the predicate is true, then do this
                                          ;prescribed something
(else do this)                  ;this is optional, if there is an else, then
                                         ;this is what happens
                                         ;if the predicate is not true
https://www.afralisp.net/autolisp/tutorials/cond-vs-if.php
That should work as it stands now. The error appears ONLY if there dimensions found, either on a locked layer [ not seen on screen probably off/frozen ]
or the Dimension object(s) are on another layout other than the current tab not accessible by command call
Try changing the ssget filter to something like this
(setq A1 (ssget "_X" (list '(0 . "DIMENSION")(Cons 410 (getvar 'ctab)))))
Edited by pBe
  • Agree 1
As a matter of mental cleanliness, I always prefer to put both conditions, regardless. I don't know BricsCAD and I used to get an error message anyway, so I prefer the confirmation message as if the condition is false.
Follow up questions...
 (vl-exit-with-error (alert "No dimension!")));;; <-- if no dimension, false condition
What if I simply want it to move on to the next step vs returning an error message?
How would this code appear?
(if (setq A1 (ssget "_X" (list '(0 . "DIMENSION")(Cons 410 (getvar 'ctab)))))
Can this be applied to all dimensions within the drawing, on all tabs vs having to tab through all tabs repeating the steps?
Thanks to all who replied.
I appreciate it greatly..
like I said the false statement is optional. so if you want to move on without any prompts don't put a false statement in. it would appear like this.
look into entmod its a visual lisp
Edited by mhupp
fixed code to only work with current tab
I don't want to say something stupid, but the code that appears in the last post is identical to the initial one, so it should come out the error message that appears in the post n°1.
Full disclosure (Novice Level)
here is what I have so far.
(defun c:d2d ()
(prin1 "A1")
(if (setq A2 (ssget "_X" '((0 . "TEXT,MTEXT"))))
 (command "change" A2 "" "P" "La" "TEXT" "co" "bylayer"  "lw" "bylayer" "lt" "bylayer"  "")
 (vl-exit-with-error (alert "No text!")))
(prin1 "A2")
(if (setq A3 (ssget "_X" '((0 . "INSERT,ATTDEF"))))
 (command "change" A3 "" "P" "La" "0" "co" "bylayer"  "lw" "bylayer" "lt" "bylayer"  "")
 (vl-exit-with-error (alert "No blocks!")))
(prin1 "A3")
(if (setq A4 (ssget "_X" '((0 . "LEADER,MULTILEADER"))))
 (command "change" A4 "" "P" "La" "DIM" "co" "bylayer"  "lw" "bylayer" "lt" "bylayer"  "")
 (vl-exit-with-error (alert "No multileaders!")))
(prin1 "A4");;-------------------------------------------good to here
(if (setq A5 (ssget "_X" (list (cons 8 "SLD-0"))))
(command "change" A5 "" "P" "La" "0" "co" "bylayer"  "lw" "bylayer" "lt" "bylayer"  "")
 (vl-exit-with-error (alert "None Found!")))
(prin1 "A5")
(if (setq A7 (ssget "_X" '((-4 . "<OR") (62 . 7) (62 . 8) (-4 . "OR>"))) )
(command "change" A7"" "P" "co" "bylayer"  "lw" "bylayer" "lt" "bylayer"  ""))
(prin1 "A7")
(princ))
Given a drawing where each statement has entities that fit the criteria, the code works perfectly until it gets to the A5 section
(the prin1 statements were added for checking purposes only). Kiddie level error checking.
When I run the routine, all the steps complete correctly but this is the response.
note: A5 & A7 complete. They "work" but I get the following errors.
Again, there are entities meeting all the criteria in this drawing.
Command: d2d
"A1""A2""A3""A4"Unknown command "P".  Press F1 for help.
Unknown command "0".  Press F1 for help.
Unknown command "CO".  Press F1 for help.
Unknown command "BYLAYER".  Press F1 for help.
Unknown command "LW".  Press F1 for help.
Unknown command "LT".  Press F1 for help.
Unknown command "D2D".  Press F1 for help.
"A5"Unknown command "P".  Press F1 for help.
"A7"
Command:
Is it obvious to those much smarter than I what the problem is?
The BYLAYER command will do much of this by itself.
I'm trying to learn here too..
the error is self generated with vl-exit-with-error So it would exit the lisp at any point if any of those if statements were false.  taken it out and it will just display the false statement. double check that their is something on the SLD-0 layer. also changed everything to prompt instead of alert because you have to click OK for it to continue. added the VLA commands so even if something is on another tab because of the ssget "X" it will still change their proprieties.
(defun c:d2d (/ A1 A2 A3 A4 A5 A7)
  (vl-load-com)
    (foreach ent (mapcar 'cadr (ssnamex A1)) ;This will change everything in A1 selection even if its on another tab.
      (vla-put-layer (vlax-ename->vla-object ent) "Dim")
      (vla-put-color (vlax-ename->vla-object ent) "256")
      (vla-put-lineweight (vlax-ename->vla-object ent) "-1")
      (vla-put-linetype (vlax-ename->vla-object ent) "ByLayer")
    (prompt "\nNo dimension!")
  (prompt "\nA1")
    (foreach ent (mapcar 'cadr (ssnamex A2))
      (vla-put-layer (vlax-ename->vla-object ent) "TEXT")
    (prompt "\nNo text!")
  (prompt "\nA2")
    (foreach ent (mapcar 'cadr (ssnamex A3))
      (vla-put-layer (vlax-ename->vla-object ent) "0")
    (prompt "\nNo blocks!")
  (prompt "\nA3")
    (foreach ent (mapcar 'cadr (ssnamex A4))
    (prompt "\nNo multileaders!")
  (prompt "\nA4")
  (if (setq A5 (ssget "_X" '((8 . "SLD-0"))))
    (foreach ent (mapcar 'cadr (ssnamex A5))
    (prompt "\nNone Found!")
  (prompt "\nA5")
  (if (setq A7 (ssget "_X" '((-4 . "<OR") (62 . 7) (62 . 8) (-4 . "OR>"))))
    (foreach ent (mapcar 'cadr (ssnamex A7))
  (prompt "\nA7")
Edited by mhupp
Thank you...
I purposely placed several objects on the SLD-0 layer just to ensure the routine would work.
Next question (should I continue in this thread or start a new one?)
  (if (setq Ax (ssget "_X" '((-4 . "<OR") (0 . DIMENSION)(3 . SLD*)(-4 . "OR>"))))
    (foreach ent (mapcar 'cadr (ssnamex Ax))
Is there an option for changing the DIMSTYLE?
I didn't see an obvious choice in the list of
(vla-put
options
maybe
(vl-cmdf
Thank you all so much for your help. I have learned quite a bit in the last couple days!!
Edited by ILoveMadoka
thanks but I already have routines to do that one thing.
That is not what I'm asking
This changes the LINETYPE
 (vla-put-linetype (vlax-ename->vla-object ent) "Phantom")
This changes the COLOR
This changes the LINEWEIGHT
This changes the TEXT WIDTH
 (vla-put-Width (vlax-ename->vla-object ent) "0.9")
This changes the FONT
 (vla-put-stylename (vlax-ename->vla-object ent) "Simplex")
Is there a VLisp command for the DIMSTYLE
Is this what I need?
VLA-PUT-ACTIVEDIMSTYLE
(vla-put-Activedimstyle (vla-get-activedocument (vlax-get-acad-object)) (vla-item (vla-get-dimstyles (vla-get-activedocument (vlax-get-acad-object))) "Name_dimstyle"))
Thank you so very much!
Please delete this post.
Please forgive my lack of understanding and application but should it be like this?
I'm obviously doing something wrong here (since I can't make it work)
                                                       (vlax-get-acad-object))) "MyDimStyle"))
Once again thank all for your help and patience...
Sorry I was under a dead line at work. Someone please correct me if I am wrong but vla-put-Activedimstyle only changes the active dimension style set in the drawing. Tried to modify what i posted to work but kept doing weird stuff. but like my buddy confutatis says "Eh, I know, but sometimes laziness..." So i just went with the vl-cmdf route.
    (progn ;added because multiple lines of code foreach and the two dimstyle commands
      (vl-cmdf "-DIMSTYLE" "RESTORE" "MyDimStyle") ;change to the style you want, only need to do this once outside foreach
      (vl-cmdf "-DIMSTYLE" "APPLY" A1 "") ; this can be applyed to everything at once so its outside the foreach for speed.
        (vla-put-layer (vlax-ename->vla-object ent) "Dim") ;this will error if Dim layer isn't created
This is a learning experience for me as well. thought you could only do matchprop to update dimstyles.
Edited by mhupp
  • Funny 1
I pirated some code from ronjonp
https://www.cadtutor.net/forum/topic/63558-change-all-existing-dimstyles-to-standard-with-a-lisp
and came up with this:
This other code
does the same thing but is one method "better" than the other?
Thanks so much to all who have helped me in all this!!
