Drop an externally saved PDF document with Lisp into the WORKINGFOLDER
Hello all, when I have saved my drawings for the customer as PDF, I still put a PDF document in the folder wich is saved outside of AutoCAD (locally on the computer).
Is it possible to retrieve this file via a Lisp (maybe with a Ghostscript) and put it in the folder where the PDF is stored (Workingfolder)?
(The PDF has multiple pages, so I can't put it on a layout in the DWG file.)
So you are wanting 2 copies of the PDF, one stored locally and one in the working folder?
Do you use a LISP to plot your PDFs? In which case I would simply change that, duplicate the line that actually plots the PDF and change the filepath part from local-folder to working-folder. Would that work?
No, the PDF has nothing to do with the drawing in AutoCAD. It is an external file that I always insert into the folder where the DWG and the drawings.PDF are saved. It is always the same PDF that I add there.
I want to automate this with command.
Look at this example (startapp "C:/Program Files (x86)/Adobe/Acrobat Reader DC/Reader/AcroRd32.exe" filename)
Or do you mean
(command "-pdfattch" filename pagenumber pt 1 0)
  • Like 2
Or do you mean
Ok i got it. You have to write the path only with double backslash \\
The forward, dbl back slashes depends a bit on file names etc if they have spaces use dbl back slashes. It is easier sometimes to just always use \\. But a syou can see / works for startapp. Yes its confusing. Dont ask about UNIX.
Edited by BIGAL
