Manuel_Kunde Posted July 5, 2021 Share Posted July 5, 2021 Hello all, when I have saved my drawings for the customer as PDF, I still put a PDF document in the folder wich is saved outside of AutoCAD (locally on the computer). Is it possible to retrieve this file via a Lisp (maybe with a Ghostscript) and put it in the folder where the PDF is stored (Workingfolder)? (The PDF has multiple pages, so I can't put it on a layout in the DWG file.) Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 5, 2021 Share Posted July 5, 2021 So you are wanting 2 copies of the PDF, one stored locally and one in the working folder? Do you use a LISP to plot your PDFs? In which case I would simply change that, duplicate the line that actually plots the PDF and change the filepath part from local-folder to working-folder. Would that work? Quote Link to comment Share on other sites More sharing options...
Manuel_Kunde Posted July 5, 2021 Author Share Posted July 5, 2021 1 hour ago, Steven P said: So you are wanting 2 copies of the PDF, one stored locally and one in the working folder? Do you use a LISP to plot your PDFs? In which case I would simply change that, duplicate the line that actually plots the PDF and change the filepath part from local-folder to working-folder. Would that work? No, the PDF has nothing to do with the drawing in AutoCAD. It is an external file that I always insert into the folder where the DWG and the drawings.PDF are saved. It is always the same PDF that I add there. I want to automate this with command. Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 5, 2021 Share Posted July 5, 2021 Will this help then? http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-12910252-217C-427D-8874-1323611FA74C Quote Link to comment Share on other sites More sharing options...
Manuel_Kunde Posted July 5, 2021 Author Share Posted July 5, 2021 1 hour ago, Steven P said: Will this help then? http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-12910252-217C-427D-8874-1323611FA74C I dont know were to start. This doesnt work. Any Idea? (defun c:meocopy (/ ) (vl-file-copy "C:/Anleitung.pdf" "C:/Autodesk/Anleitung.pdf") (vl-cmdf "start" "C:\Autodesk\Anleitung.pdf") (princ) ) (princ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 6, 2021 Share Posted July 6, 2021 Look at this example (startapp "C:/Program Files (x86)/Adobe/Acrobat Reader DC/Reader/AcroRd32.exe" filename) Or do you mean (command "-pdfattch" filename pagenumber pt 1 0) 2 Quote Link to comment Share on other sites More sharing options...
Manuel_Kunde Posted July 6, 2021 Author Share Posted July 6, 2021 8 hours ago, BIGAL said: Look at this example (startapp "C:/Program Files (x86)/Adobe/Acrobat Reader DC/Reader/AcroRd32.exe" filename) Or do you mean (command "-pdfattch" filename pagenumber pt 1 0) Ok i got it. You have to write the path only with double backslash \\ 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 7, 2021 Share Posted July 7, 2021 (edited) The forward, dbl back slashes depends a bit on file names etc if they have spaces use dbl back slashes. It is easier sometimes to just always use \\. But a syou can see / works for startapp. Yes its confusing. Dont ask about UNIX. Edited July 7, 2021 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
