chagri_charapyna Posted July 3, 2021 Share Posted July 3, 2021 Hi there, I had a code for double offset; I found one code from the forums . I needed an offset for both sides on the line and the code works well. But for the next projects I need to delete the original line and just keep the new 2 side lines. I tried to write something on the code but not works well. Can you check and help me, please ? (defun c:dOff ( / *error* of undo doc ss ) (vl-load-com) (defun *error* ( msg ) (and undo (vla-EndUndomark doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (if (and (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))) (setq of (getdist "\nSpecify Offset Distance: "))) (progn (setq undo (not (vla-StartUndomark (setq doc (vla-get-ActiveDocument (vlax-get-acad-object) ) ) ) ) ) (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc)) (mapcar (function (lambda ( o ) (vl-catch-all-apply (function vla-offset) (list obj o) ) ) ) (list of (- of)) ) ) (vla-delete ss) (setq undo (vla-EndUndoMark doc)) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
confutatis Posted July 14, 2021 Share Posted July 14, 2021 (defun c:dOff ( / *error* of undo doc ss ) (vl-load-com) (defun *error* ( msg ) (and undo (vla-EndUndomark doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (if (and (setq gru (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))) (setq of (getdist "\nSpecify Offset Distance: "))) (progn (setq undo (not (vla-StartUndomark (setq doc (vla-get-ActiveDocument (vlax-get-acad-object) ) ) ) ) ) (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc)) (mapcar '(lambda ( elem ) (vl-catch-all-apply 'vla-offset (list obj elem)) ) (list of (- of)) ) ) (vla-delete ss) (vl-cmdf "_ERASE" gru "") (setq undo (vla-EndUndoMark doc)) ) ) (princ) ) I set the ssget with the variable gru: (setq gru (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))) The gru selection is deleted: (vl-cmdf "_ERASE" gru "") Aesthetically it's a variation that might make purists cringe and I don't blame them, not least because I try to avoid the command and vl-cmdf function, but it's the one that's much quicker to write. 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted July 14, 2021 Share Posted July 14, 2021 If you don't want to use "vl-cmdf" try the following. (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex gru))) (entdel ent) ) or (repeat (setq i (sslength gru)) (entdel (ssname ss (setq i (1- i)))) ) 2 Quote Link to comment Share on other sites More sharing options...
confutatis Posted July 14, 2021 Share Posted July 14, 2021 Eh, I know, but sometimes laziness... 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted July 14, 2021 Share Posted July 14, 2021 (edited) 20 minutes ago, confutatis said: Eh, I know, but sometimes laziness... i hear you brother! id probably do the same thing. Edited July 14, 2021 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 15, 2021 Share Posted July 15, 2021 Old fashioned (command "erase" still works. We are talking microseconds for this task. Quote Link to comment Share on other sites More sharing options...
chagri_charapyna Posted July 15, 2021 Author Share Posted July 15, 2021 Thank you guys. It fits perfectly to my situation. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
