Double Offset Codes Done, Works Well - But Need to Delete Original One
chagri_charapyna
Hi there,
I had a code for double offset;  I found one code from the forums . I needed an offset for both sides on the line and the code works well. But for the next projects I need to delete the original line and just keep the new 2 side lines. I tried to write something on the code but not works well. Can you check and help me, please ?
(defun c:dOff ( / *error* of undo doc ss )
  (vl-load-com)
  (defun *error* ( msg )
    (and undo (vla-EndUndomark doc))
        (princ (strcat "\n** Error: " msg " **")))
  (if (and (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))
           (setq of (getdist "\nSpecify Offset Distance: ")))
      (setq undo
        (not
          (vla-StartUndomark
            (setq doc
              (vla-get-ActiveDocument
                (vlax-get-acad-object)
      (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
        (mapcar
          (function
            (lambda ( o )
              (vl-catch-all-apply
                (function vla-offset) (list obj o)
          (list of (- of))
      (vla-delete ss)
      (setq undo (vla-EndUndoMark doc))
  • 2 weeks later...
  (vl-load-com)
  (if (and (setq gru (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))))
      (setq undo
        (not
          (vla-StartUndomark
            (setq doc
        (mapcar
          '(lambda ( elem )
            (vl-catch-all-apply 'vla-offset (list obj elem))
          (list of (- of))
      (vla-delete ss)
      (vl-cmdf "_ERASE" gru "")
I set the ssget with the variable gru: (setq gru (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))))
The gru selection is deleted: (vl-cmdf "_ERASE" gru "")
Aesthetically it's a variation that might make purists cringe and I don't blame them, not least because I try to avoid the command and vl-cmdf function, but it's the one that's much quicker to write.
If you don't want to use "vl-cmdf" try the following.
    (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex gru)))
      (entdel ent)
or
   (repeat (setq i (sslength gru))
     (entdel (ssname ss (setq i (1- i))))
  • Like 2
20 minutes ago, confutatis said:
Eh, I know, but sometimes laziness... 😚
i hear you brother! id probably do the same thing.
Edited by mhupp
  • Agree 1
