Eslam mansour Posted June 14, 2021 Posted June 14, 2021 Is there a possibility to get lisp for block counter an total length for all line and polyline in one command ? ( export data to table ) Any ideas for merging the two lispes i attached files? CountV1-5.lspFetching info... Totallenght.lspFetching info... Quote
BIGAL Posted June 15, 2021 Posted June 15, 2021 (edited) For me I would leave seperate as you will need more columns in the table, I think it would look confusing. to do one after another just add the call to load the other program. (defun c:do2 () (if (not C:Totallenght)(load "totallength")) (if (not C:count)(load "Countv1-5")) (C:Totallength) (C:count) ) Edited June 16, 2021 by BIGAL Quote
hosneyalaa Posted June 15, 2021 Posted June 15, 2021 On 6/14/2021 at 1:36 PM, Eslam mansour said: Is there a possibility to get lisp for block counter an total length for all line and polyline in one command ? ( export data to table ) Any ideas for merging the two lispes i attached files? CountV1-5.lsp 33.41 kB · 5 downloads Totallenght.lsp 2.68 kB · 4 downloads Expand Hello @Eslam mansour I did not understand you Have you attached an example drawing? Explain the shape of the tables Quote
