gsc Posted June 11, 2021 Share Posted June 11, 2021 Hi, I was wondering if it is possible to create a closed polyline which exists of 2 offsettet Arcs and closed endcaps with circles The shape looks like a saucage (I have attached a picture). The input would be: 1. Select base point (which is always 0,0) 2. Select the 4 red Circles 3. Enter the Angle (e.g. 15 degrees) Note: the Location of the 4 red circles may be shifted in Y-direction, but the base point stays 0,0 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 11, 2021 Share Posted June 11, 2021 (edited) YES ! Have a go its the best way to learn. This is a good exercise example fairly straight forward. Write down the steps then convert to lisp. enter angle Pick centre pt while pick circle get centre and radius do some point calcs for start end of arc. arc start end 1/2 rad arc start end 1/2 rad fillet rad 0 startptarc1 startpt2 1/2rad offset rad endwhile Hints for circle (entget (car (entsel "\npick circle .....) look at (cdr (assoc 10 & (cdr (assoc 40 For start end points need to use (polar cen ang dist) +- 1/2angle of the angle from centre point to center of circle Edited June 11, 2021 by BIGAL Quote Link to comment Share on other sites More sharing options...
gsc Posted June 14, 2021 Author Share Posted June 14, 2021 Thanx for the hints, I'll try Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted June 14, 2021 Share Posted June 14, 2021 Just want to say that this is not so easy task... Quote Link to comment Share on other sites More sharing options...
devitg Posted June 14, 2021 Share Posted June 14, 2021 Just following the topic Quote Link to comment Share on other sites More sharing options...
rlx Posted June 15, 2021 Share Posted June 15, 2021 (defun c:MontyPytonsFlyingSausages ;;; variable declarations ( / ss angle-degrees point-zero angle-radians circ-ent circ-el circ-cen circ-rad circ-dist circ-ang inside-arc-dist outside-arc-dist inside-arc-LR outside-arc-UL ss->el) (defun ss->el (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (ssname ss i) l) i (1+ i))) l) ;;; main routine (if (and (setq ss (ssget '((0 . "CIRCLE")))) (setq angle-degrees (getreal "\nEnter angle offset : ")) (setq point-zero '(0.0 0.0 0.0)) (setq angle-radians (* pi (/ angle-degrees 180.0)))) (foreach circ-ent (ss->el ss) ;;; get circle elist (setq circ-el (entget circ-ent)) ;;; get circle center point (setq circ-cen (cdr (assoc 10 circ-el))) ;;; get circle radius (setq circ-rad (cdr (assoc 40 circ-el))) ;;; get angle & distance from 0,0 to circle center (setq circ-dist (distance point-zero circ-cen)) ;;; get angle between point-zero and circle (radians) (setq circ-ang (angle point-zero circ-cen)) ;;; compute distances for inside & outside arc (setq inside-arc-dist (- circ-dist circ-rad) outside-arc-dist (+ circ-dist circ-rad)) ;;; compute all arc-points (clockwise) (setq inside-arc-LR (polar point-zero (- circ-ang angle-radians) inside-arc-dist)) ;;; compute all arc-points (clockwise) (setq outside-arc-UL (polar point-zero (+ circ-ang angle-radians) outside-arc-dist)) ;;; draw pline (command ".pline" outside-arc-UL "arc" "CE" point-zero "ang" (- 0 (* angle-degrees 2.0)) inside-arc-LR "CE" point-zero "ang" (* angle-degrees 2.0) "close" ) ) ) ) ;;; shortcut (defun c:t1 ()(c:MontyPytonsFlyingSausages)) J4F (just for fun) 1 Quote Link to comment Share on other sites More sharing options...
dexus Posted June 15, 2021 Share Posted June 15, 2021 Nice one rlx! I like how you use the pline center and ang functions so you don't have to calculate all the points. When I was trying the code I did have some problems with snap. So for gsc: if you replace the last line with this, you wont have those problems. (command ".pline" "_none" outside-arc-UL "arc" "CE" "_none" point-zero "ang" (- 0 (* angle-degrees 2.0)) "_none" inside-arc-LR "CE" "_none" point-zero "ang" (* angle-degrees 2.0) "close" ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 15, 2021 Share Posted June 15, 2021 This one is a bit long winded but works as well - this follows how I would make the sausages up manually. I am putting this here because I added a check that the angle isn't greater than 360 degrees (probably should be less than that) and added a line if needed to select the centre point. I did most of this yesterday before rlx posted his solution - otherwise I would use his, his looks nicer. (vl-load-com) (defun c:sausageshape( / acount sscircle myangle centrepoint centre2 redius2 circle1 circle3 centre1 centre3 centrearc lowerarc upperarc arc3s arc1e end1 end2) (setq acount 0) (setq sscircle (ssget '((0 . "CIRCLE")))) (setq myangle (getreal "\nEnter Angle ")) (if ( >= myangle 360)(princ "Angle Too Large") (progn (Setq centrepoint "0,0,0") ;-; (setq centrepoint (getpoint "Select centre point")) ;-; if needed ;;loop (while (< acount (sslength sscircle) ) ;;get points for end arcs (command "rotate" (ssname sscircle acount) "" centrepoint "copy" (/ myangle 2) ) (setq centre1 (cdr (assoc 10 (entget(entlast))))) (entdel (entlast)) (setq centre2 (cdr (assoc 10 (entget (ssname sscircle acount)) ))) (setq radius2 (cdr (assoc 40 (entget (ssname sscircle acount)) ))) (command "rotate" (ssname sscircle acount) "" centrepoint "copy" (/ myangle -2) ) (setq centre3 (cdr (assoc 10 (entget(entlast))))) (entdel(entlast)) ;;Make Arcs (command "arc" centre1 centre2 centre3) (setq centrearc (entlast)) (command "offset" radius2 centrearc centrepoint "") (setq lowerarc (entlast)) (command "offset" (* radius2 2) lowerarc centre2 "") (setq upperarc (entlast)) (setq arc1e (vlax-curve-getEndPoint upperarc) ) (setq arc3s (vlax-curve-getStartPoint lowerarc) ) (command "_pline" arc3s "arc" "ce" centre3 "a" 180 "") (setq end1 (entlast)) (command "_pline" arc1e "arc" "ce" centre1 "a" 180 "") (setq end2 (entlast)) ;;join arcs (command "join" end1 upperarc end2 lowerarc "") (entdel centrearc) (setq acount (+ 1 acount)) ) ;end while );end progn );end if (princ) ) Quote Link to comment Share on other sites More sharing options...
devitg Posted June 15, 2021 Share Posted June 15, 2021 my other way to skin a a cat . ;; Design by Gabo CALOS DE VIT from CORDOBA ARGENTINA ;;; Copyleft 1995-2021 by Gabriel Calos De Vit ; DEVITG@GMAIL.COM ;; ; Hecho por Gabo CALOS DE VIT de CORDOBA ARGENTINA ;;; Copyleft 1995-2021 por Gabriel Calos De Vit ;; DEVITG@GMAIL.COM ;;*//*/*/*/*/*/*/*/*/*/*/*/*/**/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/* ;;;Copyright ©2005 - Marc'Antonio Alessi, Italy - All rights reserved-01 ;; http://xoomer.virgilio.it/alessi (DEFUN ALE_ENTSELFILTER (PRMSTR FLTLST / FLGSLT ENTNAM) (SETVAR "ERRNO" 0) (PRINC "\n_ ") (PROMPT (SETQ PRMSTR (STRCAT "\n" PRMSTR ": "))) (IF (WHILE (NOT FLGSLT) (IF (SETQ ENTNAM (SSGET "_:E:S" FLTLST)) (NOT (SETQ FLGSLT T)) (IF (= 52 (GETVAR "ERRNO")) (SETQ FLGSLT T) (ALERT ;;(STRCAT "\nUd no entendió lo que le pedí, pruebe de nuevo!" PRMSTR) (strcat "\nYou did not understood what I ask for , try it again!" PrmStr) ) ) ;_if ) ;_if ) ;_while (NOT (PRINC "\nFunction cancelled. ")) (SSNAME ENTNAM 0) ) ;_if ) ;_defun ;;usage ;;(ALE_EntSelFilter "Seleccione la poly del terreno" '((0 . "POLYLINE") (100 . "AcDb3dPolyline"))) ;******************************************************************************************************************** (DEFUN &-LAY-CO/NAME-COLOR (LAYER-NAME COLOR / ) (IF (= COLOR NIL) (SETQ COLOR 256) ) (IF (TBLSEARCH "LAYER" LAYER-NAME) (PROGN (SETQ LAY-NEW (VLA-ITEM LAY-COLL LAYER-NAME)) (IF (= (VLA-GET-FREEZE LAY-NEW) :VLAX-FALSE) (PRINC) (VLA-PUT-FREEZE LAY-NEW :VLAX-FALSE) ) (VLA-PUT-LAYERON LAY-NEW :VLAX-TRUE) (VLA-PUT-COLOR LAY-NEW COLOR) (VLA-PUT-ACTIVELAYER ADOC LAY-NEW) (VLA-ITEM LAY-COLL LAYER-NAME) ) ;_ progn si existe , y la descongela y la prende (PROGN (SETQ LAY-NEW (VLA-ADD LAY-COLL LAYER-NAME)) (VLA-PUT-ACTIVELAYER ADOC LAY-NEW) (VLA-PUT-COLOR LAY-NEW COLOR) LAY-NEW ) ;Progn si no existe ) ;_ controla si existe la capa ) ;************************************************************************************************************ ;;-******************************************************************************************************************************* (DEFUN TIME-INI () (SETQ INI@ (GETVAR "millisecs")) ) (DEFUN TIME-FIN () (SETQ FIN@ (GETVAR "millisecs")) (SETQ TIEMPO-INI-FIN (/ (- FIN@ INI@) 1000.0)) ) ;;****************************************************** ;;RAD TO DEG AND DEG TO RAD (DEFUN RTD (X) ;_define RADIAN TO DEGREE function (/ (* X 180.0) PI) ) ;; MULTIPLY THE RAD ING BY 180 AND DIVIDE IT BY PI (DEFUN DTR (X) ;_define DEGREE to RADIAN function (/ (* X PI) 180.0) ) ;_end dtr rtd ;;MULTIPLY THE DGR ING BY PI AND DIVIDE IT BY 180 ;;*//*/*/*/*/*/*/*/*/*/*/*/*/**/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/* ;;************************************************************ (DEFUN MAKE-SAUSAGES (/ <-ARC >-ARC ACAD-OBJ ADOC ALL-RED-CIRCLES-OBJ-SS ANGDIR ANGLE-TO-SWEP ANGLE< ANGLE<> ANGLE> ARC<CENTER ARC<END-ANGLE ARC<ST-ANGLE ARC>CENTER ARC>END-ANGLE ARC>ST-ANGLE BIG-ARC BIG-RADIUS BLOCK-COLL CLAYER DIST-FROM-URIG HALF-RADIUS INI-TIME LAY-COLL MODEL P1 P2 P3 P4 RED-CIRCLE-CENTER-VAR RED-CIRCLE-CENTER-XYZ RED-CIRCLE-OBJ RED-CIRCLE-OBJ-DIAMETER RED-CIRCLE-OBJ-LAY RED-CIRCLE-OBJ-RADIUS RED-CIRCLE-SAMPLE SELECTIONSETS SLOT-ARC-SS SMALL-ARC SMALL-RADIUS URIG URIG-TO-CENTER-ANGLE URIG-VAR ) ;;******************************************************************************************************** (VL-LOAD-COM) (SETQ ACAD-OBJ (VLAX-GET-ACAD-OBJECT)) (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT ACAD-OBJ)) (SETQ MODEL (VLA-GET-MODELSPACE ADOC)) (SETQ SELECTIONSETS (VLA-GET-SELECTIONSETS ADOC)) (SETQ BLOCK-COLL (VLA-GET-BLOCKS ADOC)) (SETQ LAY-COLL (VLA-GET-LAYERS ADOC)) (VLAX-FOR LAYER LAY-COLL (IF (NOT (= (VLA-GET-NAME LAYER) (GETVAR 'CLAYER))) (VLA-PUT-FREEZE LAYER :VLAX-FALSE) ) ) (SETVAR 'CLAYER "0") (SETQ RED-CIRCLE-SAMPLE (ALE_ENTSELFILTER "select one red circle " '((0 . "CIRCLE")))) (SETQ RED-CIRCLE-OBJ (VLAX-ENAME->VLA-OBJECT RED-CIRCLE-SAMPLE)) (SETQ RED-CIRCLE-OBJ-LAY (VLA-GET-LAYER RED-CIRCLE-OBJ)) (SETQ CLAYER (GETVAR 'CLAYER)) (&-LAY-CO/NAME-COLOR "sausage-slot" ACBLUE) (SETVAR 'CLAYER CLAYER) (SSGET "X" (LIST (CONS 0 "circle") (CONS 8 RED-CIRCLE-OBJ-LAY))) (SETQ ALL-RED-CIRCLES-OBJ-SS (VLA-GET-ACTIVESELECTIONSET ADOC)) (SETQ ANGLE-TO-SWEP (DTR 15)) (SETQ URIG (LIST 0 0 0)) (SETQ URIG-VAR (VLAX-3D-POINT URIG)) (SETQ INI-TIME (TIME-INI)) (VLAX-FOR RED-CIRCLE-OBJ ALL-RED-CIRCLES-OBJ-SS ;;; (setq red-circle-obj (VLA-ITEM all-red-circles-obj-ss 2)) (SETQ RED-CIRCLE-CENTER-XYZ (VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE (VLA-GET-CENTER RED-CIRCLE-OBJ)))) (SETQ RED-CIRCLE-CENTER-VAR (VLA-GET-CENTER RED-CIRCLE-OBJ)) (SETQ RED-CIRCLE-OBJ-RADIUS (VLA-GET-RADIUS RED-CIRCLE-OBJ)) (SETQ RED-CIRCLE-OBJ-DIAMETER (* 2.0 RED-CIRCLE-OBJ-RADIUS)) (SETQ DIST-FROM-URIG (DISTANCE URIG RED-CIRCLE-CENTER-XYZ)) (SETQ URIG-TO-CENTER-ANGLE (ANGLE URIG RED-CIRCLE-CENTER-XYZ)) (SETQ ANGDIR (GETVAR 'ANGDIR)) ; 0 for CCW , 1 for CW (SETVAR 'ANGDIR 0) (SETQ SMALL-RADIUS (- DIST-FROM-URIG RED-CIRCLE-OBJ-RADIUS)) (SETQ BIG-RADIUS (+ DIST-FROM-URIG RED-CIRCLE-OBJ-RADIUS)) (SETQ HALF-RADIUS DIST-FROM-URIG) (SETQ ANGLE< (- URIG-TO-CENTER-ANGLE ANGLE-TO-SWEP)) (SETQ ANGLE<> URIG-TO-CENTER-ANGLE) (SETQ ANGLE> (+ URIG-TO-CENTER-ANGLE ANGLE-TO-SWEP)) (SETQ P1 (POLAR URIG ANGLE< SMALL-RADIUS)) (SETQ P2 (POLAR URIG ANGLE< BIG-RADIUS)) (SETQ P3 (POLAR URIG ANGLE> SMALL-RADIUS)) (SETQ P4 (POLAR URIG ANGLE> BIG-RADIUS)) (SETQ SMALL-ARC (VLA-ADDARC MODEL (VLAX-3D-POINT URIG) SMALL-RADIUS ANGLE< ANGLE>)) (VLA-PUT-LAYER SMALL-ARC "sausage-slot") (SETQ BIG-ARC (VLA-ADDARC MODEL (VLAX-3D-POINT URIG) BIG-RADIUS ANGLE< ANGLE>)) (VLA-PUT-LAYER BIG-ARC "sausage-slot") (SETQ ARC<CENTER (POLAR URIG ANGLE< HALF-RADIUS)) (SETQ ARC>CENTER (POLAR URIG ANGLE> HALF-RADIUS)) (SETQ ARC<ST-ANGLE (ANGLE ARC<CENTER P1)) (SETQ ARC<END-ANGLE (ANGLE ARC<CENTER P2)) (SETQ ARC>ST-ANGLE (ANGLE ARC>CENTER P4)) (SETQ ARC>END-ANGLE (ANGLE ARC>CENTER P3)) (SETQ <-ARC (VLA-ADDARC MODEL (VLAX-3D-POINT ARC<CENTER) RED-CIRCLE-OBJ-RADIUS ARC<ST-ANGLE ARC<END-ANGLE)) (VLA-PUT-LAYER <-ARC "sausage-slot") (SETQ >-ARC (VLA-ADDARC MODEL (VLAX-3D-POINT ARC>CENTER) RED-CIRCLE-OBJ-RADIUS ARC>ST-ANGLE ARC>END-ANGLE)) (VLA-PUT-LAYER >-ARC "sausage-slot") (SETQ CLAYER (GETVAR 'CLAYER)) (SETVAR 'CLAYER "sausage-slot") (VLAX-FOR LAYER LAY-COLL (IF (NOT (= (VLA-GET-NAME LAYER) (GETVAR 'CLAYER))) (VLA-PUT-FREEZE LAYER :VLAX-TRUE) ) ) (SETQ SLOT-ARC-SS (SSGET "X" '((0 . "arc") (8 . "sausage-slot")))) ;(VL-CMDF "_.pedit" "m" SLOT-ARC-SS "" "j" "" "") (INITCOMMANDVERSION) ; [because otherwise, in (command) function, doesn't work quite as doing manually] (COMMAND "_.join" SLOT-ARC-SS "") ) ;end VLAX-FOR (VLAX-FOR LAYER LAY-COLL (IF (NOT (= (VLA-GET-NAME LAYER) (GETVAR 'CLAYER))) (VLA-PUT-FREEZE LAYER :VLAX-FALSE) ) ) (SETVAR 'CLAYER "0") (INITCOMMANDVERSION) ; [because otherwise, in (command) function, doesn't work quite as doing manually] (COMMAND "regen") (TIME-FIN) ) ; end DEFUN ; end VLAX-FOR (ALERT (STRCAT "it last just " (RTOS END-TIME) " seconds to do " (ITOA (VLA-GET-COUNT ALL-RED-CIRCLES-OBJ-SS)) " sausages SLOTS")) (DEFUN C:SLOTS () (MAKE-SAUSAGES) ) ;|«Visual LISP© Format Options» (200 2 1 0 nil "end of " 100 20 2 2 nil nil T nil T) ;*** DO NOT add text below the comment! ***|; make-sausages.lsp 10 sausages.dwg Quote Link to comment Share on other sites More sharing options...
gsc Posted June 18, 2021 Author Share Posted June 18, 2021 On 6/15/2021 at 8:21 AM, rlx said: (defun c:MontyPytonsFlyingSausages ;;; variable declarations ( / ss angle-degrees point-zero angle-radians circ-ent circ-el circ-cen circ-rad circ-dist circ-ang inside-arc-dist outside-arc-dist inside-arc-LR outside-arc-UL ss->el) (defun ss->el (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (ssname ss i) l) i (1+ i))) l) ;;; main routine (if (and (setq ss (ssget '((0 . "CIRCLE")))) (setq angle-degrees (getreal "\nEnter angle offset : ")) (setq point-zero '(0.0 0.0 0.0)) (setq angle-radians (* pi (/ angle-degrees 180.0)))) (foreach circ-ent (ss->el ss) ;;; get circle elist (setq circ-el (entget circ-ent)) ;;; get circle center point (setq circ-cen (cdr (assoc 10 circ-el))) ;;; get circle radius (setq circ-rad (cdr (assoc 40 circ-el))) ;;; get angle & distance from 0,0 to circle center (setq circ-dist (distance point-zero circ-cen)) ;;; get angle between point-zero and circle (radians) (setq circ-ang (angle point-zero circ-cen)) ;;; compute distances for inside & outside arc (setq inside-arc-dist (- circ-dist circ-rad) outside-arc-dist (+ circ-dist circ-rad)) ;;; compute all arc-points (clockwise) (setq inside-arc-LR (polar point-zero (- circ-ang angle-radians) inside-arc-dist)) ;;; compute all arc-points (clockwise) (setq outside-arc-UL (polar point-zero (+ circ-ang angle-radians) outside-arc-dist)) ;;; draw pline (command ".pline" outside-arc-UL "arc" "CE" point-zero "ang" (- 0 (* angle-degrees 2.0)) inside-arc-LR "CE" point-zero "ang" (* angle-degrees 2.0) "close" ) ) ) ) ;;; shortcut (defun c:t1 ()(c:MontyPytonsFlyingSausages)) J4F (just for fun) Hahahaha...You're working at the ministry of funny lisps, I guess? Working great though...Thanx! Quote Link to comment Share on other sites More sharing options...
rlx Posted June 18, 2021 Share Posted June 18, 2021 Well , actually I work at Miss , the Ministry of Silly Sausages 1 Quote Link to comment Share on other sites More sharing options...
devitg Posted June 18, 2021 Share Posted June 18, 2021 Smiles , the best pills. Quote Link to comment Share on other sites More sharing options...
