CyberAngel Posted June 9, 2021 Posted June 9, 2021 This is a weird one. My command line will stop taking keyboard input for no reason I can see. The cursor moves when I type, but the characters don't display, and pressing Enter doesn't run the command. The only fix I've found is to restart AutoCAD. The mouse still works, so I can save my work and shut down the app. The app hasn't frozen, it's just the keyboard input that's stopped. Quote
tombu Posted June 9, 2021 Posted June 9, 2021 Sure it didn't lock up? Can you run commands by clicking on the Ribbon, Menu, or Toolbars? Happens to me once a week due to a crappy graphics card. Quote
SLW210 Posted June 10, 2021 Posted June 10, 2021 Windows 10 OS? Seem to be an issue at one time, usually update (or rollback) device drivers. But here is a list I found... Quote Fix Keyboard Not Typing in Windows 10 Issue Method 1: Turn off Filter Keys Method 2: Run the Hardware and Devices troubleshooter Method 3: Uninstall Keyboard drivers Method 4: Update Keyboard Drivers Method 5: Uninstall Sypnatic Software Method 6: Run DSIM Tool Method 7: Use Standard PS/2 Keyboard Drivers Method 8: Update BIOS Method 9: Perform a Clean Boot Method 10: Repair Install Windows 10 I have my commandline turned off (CTRL+9) and use F2 if I need to see a history, etc. Quote
guran Posted June 10, 2021 Posted June 10, 2021 If you have more than one drawing open, try switching to one of the others and back again. Quote
