Hai, i need a help in editing a lisp code. I have a working lisp routine which gives me perpendicular distance to main pline when clicked on a place perpendicular to the pline i selected. Only thing i want to change is i dont need perpendicular distance from main pline but i need same main pline distance(chainage) where i click.
Pls reply if its possible... thanks:)
Attaching the lisp file and also adding same lisp code below,
(defun c:CE (/ s p c a d tp sch)
(setvar "cmdecho" 0)
  (setq sch (getstring "\nSpecify start chainage : <0>"))			;"0" is set as the default value
  (if (= sch "")(setq sch "0"))
  (if
    (and (setq s (car (entsel "\nPick a polyline :")))
	 (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE")
	     (alert "Invalid object! Please pick a polyline only.")
     (while
       (and
	 (setq
	   p (getpoint "\nSpecify point perpendicular to polyline :")
	 (setq c (vlax-curve-getclosestpointto s p))
	 (setq a (angle p c))
	 (not (grdraw p c 1 -1))
	 ;; rubber line in red colour.
	 (setq d (angle	'(0. 0. 0.)
			(vlax-curve-getfirstderiv
			  s
			  (vlax-curve-getparamatpoint s c)
	 (or
	   (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4)
	       (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4)
	   (alert
	     "Picked point is not a perpendicular to picked polyline. <!>"
	 (setq tp (getpoint "\nSpecify Point for Text : "))
		(command "_.LEADER" p tp ""
				(strcat "CH=" sch "+" (rtos (vlax-curve-getdistatpoint s c) 2 3))
				(strcat "E=" (rtos (car p) 2 3))
				(strcat "N=" (rtos (cadr p) 2 3))
		(vlax-put-property (vlax-ename->vla-object (entlast)) 'height 0.60);;; Text Height 0.60
  (setvar "cmdecho" 1)
(vl-load-com)
COORD & CHAIN - FINAL AB.LSPUnavailable
Maybe  this can help you, it's a great program from Lee Mac.
It is very easy there is a vl function note though it will be always from start of pline. A quicky effort
(defun c:getdist ( / oldsnap pt ent)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 512)
(setq ent (entsel "Pick obj"))
(while (setq pt (getpoint "\nPick point Enter to exit"))
(princ (vlax-curve-getdistatpoint (vlax-ename->vla-object (car  ent)) pt))
(setvar 'osmode oldsnap)
Expand
@BIGAL
No need to convert the entity to an object, the curve functions are actually faster with enames.
(vlax-curve-getdistatpoint (car  ent) pt)
_$
Benchmarking ....................Elapsed milliseconds / relative speed for 131072 iteration(s):
    (vlax-curve-getDistAtPoint E P)..............1656 / 4.43 <fastest>
    (vlax-curve-getDistAtPoint (vlax-ena...).....7344 / 1.00 <slowest>
; 1 form loaded from #<editor "<Untitled-0> loading...">
_$
Edited by ronjonp
its not working as i wanted, but its giving output, Thank You.
i have a lisp code here, its working in polyline but not points above it. when i use measure command to the polyline, the points are created . when i pick the points to get the chainage ,its showing error. is it possible to get polyline length even if i click the points above it? Please check if possible. other than that the lisp is working wonderfully. hak_vz helped in it.
(defun c:CE (/ s p c tp sch f)
  (if
     (while
       (and
	 (setq
	   p (getpoint "\nSpecify point :")
	  (setq di (vlax-curve-getdistatpoint s p))
	  (setq f (fix (/ di 1000.0)))
	  (setq di (- di (*  f 1000.0)))
				(strcat "CH=" (itoa (+ (atoi sch) f)) "+" (rtos di 2 3))
  (if
     (while
       (and
	 (setq
Expand
REPLACE THIS
WITH THIS
(setq di (vlax-curve-getdistatpoint s c))
Thank you. it works well now... Thanks
Its a great code, Thanks all for this. I have a small request to make
can the text be further formatted to 00+000.000 instead of 0+00.000
Thanks in advance
Thanks in advance
REPLACE this
With this
(if (= sch "")(setq sch "00"))
  On 6/6/2021 at 9:37 AM, hosneyalaa said:
REPLACE this
With this
Expand
hosneyalaa, thanks for your help. But its not showing any difference in results.
And
REPLACE
With
(strcat "CH=" (itoa (+ (atoi sch) f)) "+0" (rtos di 2 3))
  On 6/6/2021 at 11:37 AM, hosneyalaa said:
And
REPLACE
With
Expand
Here the values less than 100 are good, but 100 and above are not true...
please look into this..
Thanks for all your time and efforts..
  • 2 years later...
  On 6/5/2021 at 7:30 AM, hosneyalaa said:
REPLACE THIS
WITH THIS
Expand
Thank you very much. Works excellent.
I have 2 question
Is it chance to have text perpendicular to polyline ?
And more difficult is it possible to add this lisp to block?
I would like to put block and attribute of block will have a station on this point.
Once again thank you :)
All best
I'm just trying to change that but I don't know autolisp code 😕
