VisDak Posted May 31, 2021 Share Posted May 31, 2021 Hi All, I need help for this Lsp to select all Gradient hatches and delete. (defun c:delsolidhatch () (sd) (delbht) (princ "\nAll Solids have been deleted!") (princ) ) (defun sd (/) (Setq sd (ssget "_x" '((0 . "SOLID")))) (command "_.erase" sd "") ) (defun delbht () (setq Block1 (tblnext "BLOCK" T)) (setq Bname1 (cdr (assoc -2 Block1))) (Fixh Bname1) (princ) );defun ;;----------------------- (defun Fixh () (Setq ht2 (ssget "_x" '((0 . "SOLID")))) (command "_.erase" ht2 "") (princ) );defun Many Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 31, 2021 Share Posted May 31, 2021 Have you looked at the properties of a HATCH use (entget (car (entsel "pick hatch"))) or (vlax-dump-object (vlax-ename->vla-object (car (entsel "Pick obj")))) Quote Link to comment Share on other sites More sharing options...
hmsilva Posted June 1, 2021 Share Posted June 1, 2021 Group code 450 0 = Solid hatch 1 = Gradient (ssget "_X" '((0 . "HATCH")(450 . 1))) Hope this helps, Henrique 1 Quote Link to comment Share on other sites More sharing options...
