Delete all Gradient hatches
VisDak
Hi All,
I need help for this Lsp to select all Gradient hatches and delete.
(defun c:delsolidhatch ()
        (sd)
      (delbht)
(princ "\nAll Solids have been deleted!")
(defun sd (/)
   (Setq sd (ssget "_x" '((0 . "SOLID"))))
(command "_.erase" sd "")
(defun delbht ()
   (setq Block1 (tblnext "BLOCK" T))
   (setq Bname1 (cdr (assoc -2 Block1)))
(Fixh Bname1)
);defun
(defun Fixh ()
  (Setq ht2 (ssget "_x" '((0 . "SOLID"))))
(command "_.erase" ht2 "")
);defun
Many Thanks
Have you looked at the properties of a HATCH use
(entget (car (entsel "pick hatch")))
or
(vlax-dump-object (vlax-ename->vla-object (car  (entsel "Pick obj"))))
