I am running into error when I am running my routine. It basically states a draworder based upon xref drawing names.
In some instances, the drawing I run this in does not have an Aerial , or Building. But usually once it activates that command it stops and does not finish the routine.
(command "._DRAWORDER" (ssget "_x" '((0 . "INSERT")(2 .  "*Aerial*"))) "" "_B")
(command "._DRAWORDER" (ssget "_x" '((0 . "INSERT")(2 .  "*Proposed*"))) "" "_B")
(command "._DRAWORDER" (ssget "_x" '((0 . "INSERT")(2 .  "*survey*"))) "" "_B")
(command "._DRAWORDER" (ssget "_x" '((0 . "INSERT")(2 .  "*Building*"))) "" "_B")
Anyone have an idea around this possibly? Thank you!
Use if statements
If anything selected use Draworder command on the selection set else skip it
(if (setq SS (ssget "_x" '((0 . "INSERT") (2 . "*Aerial*"))))
  (vl-cmdf "._DRAWORDER" SS "" "_B")
(if (setq SS (ssget "_x" '((0 . "INSERT") (2 . "*Proposed*"))))
(if (setq SS (ssget "_x" '((0 . "INSERT") (2 . "*survey*"))))
(if (setq SS (ssget "_x" '((0 . "INSERT") (2 . "*Building*"))))
Edited by mhupp
Changed 'set to 'setq
Awesome! that makes sense...
Here's another way to refactor it:
(foreach f '("*Aerial*" "*Proposed*" "*survey*" "*Building*")
  (if (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 f))))
    (vl-cmdf "._DRAWORDER" ss "" "_B")
Or if you're just sending them all to back without regard to each other:
(if (setq ss (ssget "_x" '((0 . "INSERT") (2 . "*Aerial*,*Proposed*,*survey*,*Building*"))))
Edited by ronjonp
*changed 'set to 'setq'
Sorry to bring this up again. I do know what happened. It was working but now get the following error.
From what I see everything looks ok.
Command: basic
; error: bad argument type: symbolp nil
(defun c:Basic (/ ss)
(if (set ss (ssget "_x" '((0 . "INSERT") (2 . "*Aerial*,*Proposed*,*survey*,*Building*"))))
  (if (set ss (ssget "_X" (list '(0 . "INSERT") (cons 2 f))))
(princ))
Thank you for any help.
Command: basic
(princ))
Not sure what is going on but why are you running both of the draworder functions?
Sorry i was using it to test with. I just commented out the other line.
i don't know but it has set instead of setq is that a thing?
(defun c:Basic ()
    (if (setq ss (ssget "_X" '((0 . "INSERT") (cons 2 f))))
lol looks like we all did it.
Hahahaha .. that's what a copy paste gets you 😅
Edited by ronjonp
Interesting...  Something like that. It seems its working. so guilty with the copy paste thing lol. Thank you again guys!
For your info SET is a valid function used often to create variables on the fly.
(set 'a "abc")
(setq num 123)
(setq abc "werrt")
(set (read (strcat "X" (rtos num 2 0))) abc)
Edited by BIGAL
Another example:
(mapcar 'set '(a b c) '(1 2 3))
(mapcar 'print (list a b c))
