flowerrobot Posted February 10, 2009 Posted February 10, 2009 WHile i was waiting for some info i decieded to delve into my first reator. the only problem is. some thing is setting "oldlayer" to dim. when it should be set to the layer i had before i ran the command. i must be missing some thing any help would be great (vl-load-com) (vlr-command-reactor nil '((:vlr-commandWillStart . startCommand))) (vlr-command-reactor nil '((:vlr-commandEnded . endCommand))) (vlr-command-reactor nil '((:vlr-commandCancelled . cancelCommand))) ;****************************************************** (defun startCommand (calling-reactor startcommandInfo / thecommandstart) (setq OldLayer (getvar "CLAYER")) (setq thecommandstart (nth 0 startcommandInfo)) (cond ((= thecommandstart "dimdiameter") (setvar "CLAYER" "dim")) ((= thecommandstart "DIMALIGNED") (setvar "CLAYER" "dim")) ((= thecommandstart "DIMLINEAR") (setvar "CLAYER" "dim")) ((= thecommandstart "dimradius") (setvar "CLAYER" "dim")) ((= thecommandstart "dimangular") (setvar "CLAYER" "dim")) );cond (princ) );defun ;**************************************************** (defun endCommand (calling-reactor endcommandInfo / thecommandend) (setq thecommandend (nth 0 endcommandInfo)) (cond ((= thecommandend "dimdiameter") (setvar "CLAYER" OldLayer)) ((= thecommandend "dimlinear") (setvar "CLAYER" OldLayer)) ((= thecommandend "DIMLINEAR") (setvar "CLAYER" OldLayer)) ((= thecommandend "dimradius") (setvar "CLAYER" OldLayer)) ((= thecommandend "dimangular") (setvar "CLAYER" OldLayer)) );cond (princ) );defun ;******************************************************** (defun cancelCommand (calling-reactor cancelcommandInfo / Thecommandcancel) (setq thecommandcancel (nth 0 cancelcommandInfo)) (cond ((= thecommandcancel "dimdiameter") (setvar "CLAYER" OldLayer)) ((= thecommandcancel "dimlinear") (setvar "CLAYER" OldLayer)) ((= thecommandcancel "DIMLINEAR") (setvar "CLAYER" OldLayer)) ((= thecommandcancel "dimradius") (setvar "CLAYER" OldLayer)) ((= thecommandcancel "dimangular") (setvar "CLAYER" OldLayer)) );cond (princ) );defun ;********************************************************* (princ) cheers flower Quote
ASMI Posted February 10, 2009 Posted February 10, 2009 Hi 1. One reactor with three events is enough. 2. Two callback functions is enough. 3. You should create "dim" layer 4. You may use WCMATCH or MEMBER instead COND. (vl-load-com) (vlr-command-reactor nil ' ((:vlr-commandWillStart . startCommand) (:vlr-commandEnded . endcancelCommand) (:vlr-commandCancelled . endcancelCommand)) ); end vlr-command-reactor (if(vl-catch-all-error-p (vl-catch-all-apply 'vla-Item (list(setq layerCol(vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))) "dim"))) (vla-Add layerCol "dim") ); end if ;****************************************************** (defun startCommand (calling-reactor startcommandInfo) (setq OldLayer (getvar "CLAYER")) (if(wcmatch(car startcommandInfo)"DIM*") (setvar "CLAYER" "dim") ); end if (princ) );defun ;**************************************************** (defun endcancelCommand (calling-reactor endcommandInfo) (if(wcmatch(car endcommandInfo)"DIM*") (setvar "CLAYER" OldLayer) ); end if (princ) );defun Quote
flowerrobot Posted February 10, 2009 Author Posted February 10, 2009 Thank heaps for you advice. but i suffered from the same problem... But i remembered that reactors do not always follow set order of things, so it was changing to dim layer then seting oldlayer. so to fix my solution if places it before the command begin, This worked only in one dwg, then it gave me errors so i placed it at the top again. and that works only is some dwg. IS their a solution to have it run first thanks again, (vl-load-com) (vlr-command-reactor nil ' ((:vlr-commandWillStart . startCommand) (:vlr-commandEnded . endcancelCommand) (:vlr-commandCancelled . endcancelCommand)) ); end vlr-command-reactor (if(vl-catch-all-error-p (vl-catch-all-apply 'vla-Item (list(setq layerCol(vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))) "dim"))) (vla-Add layerCol "dim") [color=Red](setq OldLayer (getvar "CLAYER"))[/color] ); end if ;****************************************************** (defun startCommand (calling-reactor startcommandInfo) [color=Lime](setq OldLayer (getvar "CLAYER"))[/color] (if (= 1 (getvar "dimlfac")) (setvar "dimclrt" 2) (setvar "dimclrt" 3) ) (if(wcmatch(car startcommandInfo)"DIM*") (setvar "CLAYER" "dim") ); end if (princ) );defun ;**************************************************** (defun endcancelCommand (calling-reactor endcommandInfo) (if(wcmatch(car endcommandInfo)"DIM*") (setvar "CLAYER" OldLayer) (setvar"dimclrt" 2) ); end if (princ) );defun Quote
