Malfunctions if I load many lisp
X11start
Why if I load and launch one of my lisp, then I load another ... the previous one has malfunctions? Ex. Asks me questions that are part of the 2nd lisp loaded? I thought that it was the fact that I use the same variables and that these were not "closed" inside the lisp (or placed at "nil" before exit). But then I found that this happens even when my lisp is "well done"!
I have never asked myself the problem and I have always solved it by loading immediately before using the lisp that interests me 🙂
One may be setting a system or environmental variable that affects how the other works. Hard to tell without seeing both codes.
It's best to use error handling to make sure your routines reset any changes even when you use Esc to get out of them.
Do either of them use USER* system variables, global variables or reactors?
You probably have an open paren or missing close in one of your lisp that is causing the error. That will sometimes make two lisp interact with each other.
35 minutes ago, tombu said:
Uno potrebbe impostare un sistema o una variabile ambientale che influisce sul funzionamento dell'altro. Difficile da dire senza vedere entrambi i codici.
È meglio usare la gestione degli errori per assicurarti che le tue routine ripristinino le modifiche anche quando usi Esc per uscirne.
Entrambe utilizzano variabili di sistema USER *, variabili globali o reattori?
I don't use reactors or USERS variables. Maybe it's just a matter of variables
"normal" reused and not reported to NIL!
I don't think you can have non-closed brackets .... and a working lisp.
However, it is easily circumvented by doing LOAD once.
Thanks for the replies.
Example:
- I open a new drawing, I load "Copiatxt" (it is used to copy a text from another),
- I execute the command and I make 2 texts equal.
- Load of "Freccia" (used to create an arrow made with a polyline), I also execute this command.
- Finally I launch (without loading!) in the command line "Copiatxt" .... it asks me for the vertex of the arrow!
COPIATXT.LSP FRECCIA.LSP
Your using a lot of global variables maybe their is a shared few between the two lisp? its good house keeping to clear those out after the command is run.
(defun indati ()
to
(defun indati (/ modes stiletxt entl entbl ent entb lis lisl txt nuo lis2)
nm see your doing that in COPIATXT
in COPIATXT you have a function called indati
in FreeCCIA you have a function called INDATI
change the names of them and it will clear up your problem
when the function is called in FreeCCIA.lsp its going to the first time it sees that function and its in COPIATXT.lsp because it was loaded first
Edited by mhupp
Se scrivo! INDATI dalla riga di comando ottengo:
# <SUBR @ 000000002EB9AC48 INDATI>
quindi forse potrei scrivere: (setq INDATI nil) alla fine di ogni lisp ... forse risolve il problema....
No i tried: it kill both lisp files!
Edited by X11start
it needs to be named different because its going to go where it see it first and the lisp You load first that's where its going to go.
in COPIATXT name the function INDATI-C
in FreeCCIA name the function INDATI-F
When you load lisp they are essentially in one file and it reads top down. your tying to get to the 2nd INDATI function but it will always stop at the first one if they are named the same.
Edited by mhupp
ALL my lisp have "INDATI"!
Well now I know what the problem is! 😱
Thank you very much Mhup 👍
This is not correct. Functions can be redefined by (re)loading Lisp files. So it is the function definition from the Lisp file that was loaded last that will be used.
Edited by Roy_043
  • Thanks 1
Oops got it backwards. just know its not good to have multiple functions that do different things named the same.
Last in First out! Got it.
In all my lisp "INDATI" is the routine that has the task of requesting all the data and then sending them to the various processing ... maybe I should simply move this task to the main routine: "DEFUN C : ..." which obviously has different names for each lisp.
thank you all
Edited by X11start
Listen to mhupp and update all your code to use local variables!
Using localized variables for subfunctions as well would avoid even more issues.
Instead of changing and having to restore *error* Error handler simply add *error* as a local variable then define *error* inside your routine and it restores itself when you exit the routine.
Had you localized INDATI in each routine you wouldn't have had issues with it either.
This may cause some problems using extended characters. Just a comment.
ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
The 2 indati are very different also noted only runs once so a defun is not really needed as you suggested put in main code.
thanks everyone for the tips.
I apologize if I don't write well in English: I'm much better with Italian! 😜
Another suggestion
(setq ent (entsel "\nClicca sul testo da modificare (Invio=Fine) : "))
