joa0009 Posted May 28, 2021 Share Posted May 28, 2021 modify the code so that it only displays the donuts and at the end display the number of donuts on the drawing Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 28, 2021 Share Posted May 28, 2021 All that code is doing is. if the user select something stepping though each item say what it is. If you selected 3 lines it would output line line line is donuts a block? check this out Quote Link to comment Share on other sites More sharing options...
joa0009 Posted May 28, 2021 Author Share Posted May 28, 2021 2 minutes ago, mhupp said: All that code is doing is. if the user select something stepping though each item say what it is. If you selected 3 lines it would output line line line is donuts a block? check this out Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 28, 2021 Share Posted May 28, 2021 Donuts dont exist long I just ate the last one. Oh yeah a donut is a Lwpolyline. 2 Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 28, 2021 Share Posted May 28, 2021 (edited) This selects lwpolylines that are closed and have only have 2 radius aka donuts. maybe something else idk donuts dont really have a call out like other entity like lines, blocks, circles from what Im reading. Will select everything it counted when the command ends. You don't need to step thought everything take your if statements and apply them in the ssget. (defun C:TEST () (setq SS (ssget "X" '((0 . "lwpolyline")(70 . 1)(90 . 2)))) (prompt (strcat "\n"(itoa (sslength SS)) " Donuts in the Drawing")) (sssetfirst nil SS) (princ) ) Edited May 28, 2021 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 28, 2021 Share Posted May 28, 2021 15 hours ago, joa0009 said: modify the code so that it only displays the donuts and at the end display the number of donuts on the drawing That code is directly copied from my site here... http://lee-mac.com/selsetprocessing.html#revrepeat Quote Link to comment Share on other sites More sharing options...
joa0009 Posted May 29, 2021 Author Share Posted May 29, 2021 13 hours ago, Lee Mac said: That code is directly copied from my site here... http://lee-mac.com/selsetprocessing.html#revrepeat My teacher has a good place for inspiration Quote Link to comment Share on other sites More sharing options...
joa0009 Posted May 29, 2021 Author Share Posted May 29, 2021 Thx all! Quote Link to comment Share on other sites More sharing options...
Steven P Posted May 29, 2021 Share Posted May 29, 2021 however if your teacher (unless it is Mr Mac himself) had any credibility they would credit the original source of the code 1 Quote Link to comment Share on other sites More sharing options...
