tombu Posted May 27, 2021 Share Posted May 27, 2021 I often use Lee Mac's Load Linetypes code as it looks first for them in default lin files for both AutoCAD and BricsCAD then Metric or Imperial versions, then any other lin files in the support path. It also provides the option to reload the linetype if you wish. Lee's code also uses vl-cmdf in place of command-s in versions or software that doesn't support command-s. I keep separate lin files named for Text Styles they reference like Arial or Wingdings and this makes loading them simpler with macros that also import the Text Styles as needed. Example code that should work with Metric or Imperial versions on AutoCAD or BricsCAD: (load "LoadLinetypesV1-3.lsp")(LM:LoadLinetypes '("phantom") T) (setq ss (ssget "_X" '((0 . "LWPOLYLINE") (67 . 1) (8 . "0") (62 . 6) (6 . "CENTER2")))) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (vlax-put obj 'Linetype "Phantom") (vlax-put obj 'LinetypeScale 0.25) ) The (OR function evaluates a list of expressions only till one of them is true so if (tblsearch "ltype" "PHANTOM") is not nil (command-s "._linetype" "_load" "PHANTOM" "acad.lin" "") would not be evaluated or run in (or(tblsearch "ltype" "PHANTOM")(command-s "._linetype" "_load" "PHANTOM" "acad.lin" "")) allowing it to generally replace (IF (NOT in code. Quote Link to comment Share on other sites More sharing options...
