Exporting Palettes
Dragon
This should be easy but I am having a problem with it.
To export a custom tool palette all you should have to do is open the customization file right click the palette you want and in the pop up list it should have a export option...........Well mine only has Rename, Delet or New Palette. Oh I am in autodesk 2007
Rt-clk the tool palette menu bar > Customize Palletes > Rt-clk palette name in left panel > Export
Thanks for getting back with me.....But
The problem I am having is the dialog box that comes up typically has the foloowing
Rename
New Palette
Delete
_____________
Export
Import
I have attached a snap shot of my screen showing this. How do I get the Export and Import options to show up on this pop up menue list?
That's a new one on me, I thought maybe you were rt-clicking on the toolpalette tab, not the menu bar. This is a long shot... are the files and folders that contain the toolpalettes read only?
