adamsimpson Posted May 18, 2021 Share Posted May 18, 2021 Hi. My cursor changed into X and Y axis on 2D drawing as shown on the attached image below (red circle) and my background gridline also became axonometric instead of normal gridline. How can I change it back? I am using Autocad 2021 on Window 10. Thank you in advance! Quote Link to comment Share on other sites More sharing options...
tombu Posted May 18, 2021 Share Posted May 18, 2021 See: 1 Quote Link to comment Share on other sites More sharing options...
guran Posted May 18, 2021 Share Posted May 18, 2021 Isometric Drawing in AutoCAD https://www.cad-notes.com/isometric-drawing-in-autocad/ 1 Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 18, 2021 Share Posted May 18, 2021 I prefer to just swivel the monitor 30 deg then 60 deg and back again. This can't happen accidentally unless you have the ISODRAFT icon on your task bar and click it while trying to hit something else. Simply click it until your screen looks good again. When they first added the button, some of us (um ah coff coff um, not me) used it for practical joking others. Maybe you should give a co-worker a sidelong glance or two. Carful, they may think you are flirting. Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted May 18, 2021 Share Posted May 18, 2021 (edited) UCS command -> V(iew) should change the crosshair to your current orientation (Using PLAN command <enter> <enter>, changes the view to the orientation of the crosshair, in case you want to know). And in any case setting the UCS to World and then use PLAN <enter><enter> should bring you to a starting orientation (topdown view, Z=0 and Y= North). Edited May 18, 2021 by OMEGA-ThundeR Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 25, 2021 Share Posted May 25, 2021 It is customary to indicate whether we were helpful or not. Quote Link to comment Share on other sites More sharing options...
