Amalia Posted May 15, 2021 Share Posted May 15, 2021 (edited) Hi! So I have this Lisp code that selects all circles found in the drawing and moves them to have the same center (specified by user). I want to also change the colors of the circles to red ( or anything else really ) but I have no idea how to do that. Can anyone help me? (defun C:CIRCLES (/ ss n) (setq newCenter (getpoint "The new center: ")) (setq circles (ssget "X" '((0 . "CIRCLE")) )) (setq n (sslength circles)) (setq x 0) (repeat n (setq name (ssname circles x)) (setq circle (entget name)) (setq center (cdr (assoc 10 circle))) (setq circle (subst (cons 10 noulCentru) (assoc 10 circle) circle)) (entmod circle) (setq x (+ 1 x)) ) (princ) ) Edited May 16, 2021 by CADTutor Code moved to code block Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 16, 2021 Share Posted May 16, 2021 I would suggest the following: (defun c:circles ( / i s x ) (cond ( (not (setq s (ssget "_X" (list '(0 . "CIRCLE") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))) (princ "\nNo circles were found in the active drawing layout or viewport.") ) ( (setq c (getpoint "\nSpecify new centre: ")) (repeat (setq i (sslength s)) (setq i (1- i) x (entget (ssname s i)) x (subst (cons 10 (trans c 1 (cdr (assoc 210 x)))) (assoc 10 x) x) x (append x '((62 . 1))) ) (entmod x) ) ) ) (princ) ) A few point to note on the above: I use a cond statemtent to test whether the selection set exists prior to evaluating other selection set functions (such as sslength) - else these functions will error if supplied with a null selection set. I use the second cond test expression to test the validity of the point supplied by the user, to account for the possibility of the user dismissing the prompt. I filter the selection set to only consider circles residing in the current layout/viewport, rather than in all layouts. Appending DXF group 62 is the easiest way to update the object colour: this accounts for the possibility of the object colour being set to ByLayer (in which case, no DXF group 62 entry will be present in the DXF data with which to use subst), and if an existing entry for DXF group 62 exists in the DXF data, this will be overridden by the last entry in the list. 1 Quote Link to comment Share on other sites More sharing options...
