Handiman Posted May 14, 2021 Posted May 14, 2021 I updated to 2022 and some of my preferences have change and I'm trying to get everything back to my liking. So what I'm having issue with is when I have a poly line and I select it, Normally when I put my cursor on a grip I would get an option to make it an arc, add another vertex (point) Now I don't get that window, I get nothing. Any ideas on what box I need to check to get the options? Thanks for your time. Quote
Cad64 Posted May 14, 2021 Posted May 14, 2021 See if this helps: At the command line type GRIPMULTIFUNCTIONAL and change the setting to 2 or 3. Or go to OPTIONS > Selection tab > Grips section and make sure "Show dynamic grip menu" is enabled. Quote
tombu Posted May 14, 2021 Posted May 14, 2021 (edited) Setting GRIPS (System Variable) to 2 Displays additional midpoint grips on polyline segments. Setting GRIPMULTIFUNCTIONAL to 2 Multifunctional grip options can be accessed with the grip menu displayed when you hover over a grip. Add (if (/= (getvar 'gripmultifunctional) 3)(progn(setvar 'gripmultifunctional 3)(princ "\nMultifunctional grip options can be accessed with both Ctrl-cycling and the grip menu. GRIPMULTIFUNCTIONAL"))) (if (/= (getvar 'grips) 2)(progn(setvar 'grips 2)(princ "\nDisplays additional midpoint grips on polyline segments. GRIPS"))) to acaddoc.lsp and you'll never have to worry about it again. Edited May 14, 2021 by tombu Quote
