Terry.T Posted May 13, 2021 Share Posted May 13, 2021 Hi, I am a beginner and I had a problem about sorting. I had many block with attributes "SORT_ORDER" and "NUMBER" what i want to do is : 1. Select all block in a list (setq lst1 (ssget "x" '((8 . "layer")))) 2. sort list by attributes "SORT_ORDER" (no idea) 3.apply new number by lst1 form 001 to 100 into attributes (3 digit). Because we need to change the number many many time but the number must in order. such as block format:("SORT_ORDER"== "NUMBER") (1==001), (2== 002), (3== 003), (4== 004), (5== 005), (6== 006), (7== 007) we want to del 3 (1== 001), (2==002), (4== 003), (5== 004), (6== 005), (7== 006) and add back 3 and add 2.1 between b and c (1== 001), (2== 002, (2.1== 003), (3== 004), (4== 005), (5== 006), (6== 007), (7== 008) Thanks, Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 13, 2021 Share Posted May 13, 2021 (edited) look into this function https://documentation.help/AutoLISP-Functions/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-687f.htm Edited May 13, 2021 by mhupp Quote Link to comment Share on other sites More sharing options...
hosneyalaa Posted May 13, 2021 Share Posted May 13, 2021 5 hours ago, Terry.T said: Hi, I am a beginner and I had a problem about sorting. I had many block with attributes "SORT_ORDER" and "NUMBER" what i want to do is : 1. Select all block in a list (setq lst1 (ssget "x" '((8 . "layer")))) 2. sort list by attributes "SORT_ORDER" (no idea) 3.apply new number by lst1 form 001 to 100 into attributes (3 digit). Because we need to change the number many many time but the number must in order. such as block format:("SORT_ORDER"== "NUMBER") (1==001), (2== 002), (3== 003), (4== 004), (5== 005), (6== 006), (7== 007) we want to del 3 (1== 001), (2==002), (4== 003), (5== 004), (6== 005), (7== 006) and add back 3 and add 2.1 between b and c (1== 001), (2== 002, (2.1== 003), (3== 004), (4== 005), (5== 006), (6== 007), (7== 008) Thanks, Attached drawing example pls Quote Link to comment Share on other sites More sharing options...
Terry.T Posted May 14, 2021 Author Share Posted May 14, 2021 TEST-LSP FOR NUMBING2.dwg thanks for the reply. and here is what i am doing yesterday. (defun C:nm ( / sel1 sel2 ) (setq num 0) (setq lop 0) (setq sel1 (ssget "x" '((8 . "NUMBERING")))) (foreach pp1 (ssnamex sel1) (setq num (1+ num)) ) (foreach pp (ssnamex sel1) (setq sel2 (ssname sel1 lop)) (setq a (entnext sel2)) (setq b (entnext a)) (setq c (entget b)) (setq d (assoc 1 c)) (setq e (cdr d)) (setq num (1- num)) (setq lop (1+ lop)) (setq a1 (cons e a1)) ) ;foreach (vl-sort a1 '<) );end defun 13 hours ago, hosneyalaa said: Attached drawing example pls i am not sure is it a right way to sort the block. Thanks. Quote Link to comment Share on other sites More sharing options...
Terry.T Posted May 14, 2021 Author Share Posted May 14, 2021 14 hours ago, mhupp said: look into this function https://documentation.help/AutoLISP-Functions/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-687f.htm Thank for the reply, I am trying to use vl-sort, but i can't find the right way to sort it. i think it is sorting the number only, not the block. Thanks. Quote Link to comment Share on other sites More sharing options...
Terry.T Posted May 14, 2021 Author Share Posted May 14, 2021 TEST-LSP FOR NUMBING2.dwg hi all i think this file will better than before. Thank again. Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 14, 2021 Share Posted May 14, 2021 (edited) try this (defun C:nm (/ ss i blk atts lst a1 P O) (vl-load-com) (setq ss (ssget '((0 . "INSERT") (8 . "NUMBERING")))) ;only select blocks on numbering layer (repeat (setq i (sslength ss)) (setq blk (vlax-ename->vla-object (ssname SS (setq i (1- i)))) atts (vlax-safearray->list (vlax-variant-value (vla-getattributes blk))) ) (foreach x atts (if (= (vla-get-tagstring x) "PORT_NUMBER") (setq P (vla-get-textstring x)) (setq O (vla-get-textstring x)) ) ) (setq lst (list P O)) ;create a mini list (setq a1 (append a1 (list lst))) ;join all mini lists into big list ) (vl-sort a1 '(lambda (x y) (< (car x) (car y)))) ;sort by first item in the mini list ) 3. I don't know what you mean. Edited May 14, 2021 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 16, 2021 Share Posted May 16, 2021 Another - (defun c:pno ( / a c i l n p q s x ) (if (setq s (ssget "_X" '((0 . "INSERT") (8 . "NUMBERING")))) (progn (repeat (setq i (sslength s)) (setq i (1- i) a (entnext (ssname s i)) x (entget a) ) (while (and (= "ATTRIB" (cdr (assoc 0 x))) (not (and p n))) (cond ( (= "PORT_NUMBER" (cdr (assoc 2 x))) (setq p a) ) ( (= "SORT_ORDER" (cdr (assoc 2 x))) (setq n (atoi (cdr (assoc 1 x)))) ) ) (setq a (entnext a) x (entget a) ) ) (if (and p n) (setq l (cons p l) p nil q (cons n q) n nil ) ) ) (setq c 1) (foreach n (vl-sort-i q '<) (entmod (list (cons -1 (nth n l)) (cons 1 (padz (itoa c) 3)))) (setq c (1+ c)) ) ) ) (princ) ) (defun padz ( x n ) (if (< (strlen x) n) (padz (strcat "0" x) n) x) ) (princ) 1 Quote Link to comment Share on other sites More sharing options...
Terry.T Posted May 17, 2021 Author Share Posted May 17, 2021 12 hours ago, Lee Mac said: Another - (defun c:pno ( / a c i l n p q s x ) (if (setq s (ssget "_X" '((0 . "INSERT") (8 . "NUMBERING")))) (progn (repeat (setq i (sslength s)) (setq i (1- i) a (entnext (ssname s i)) x (entget a) ) (while (and (= "ATTRIB" (cdr (assoc 0 x))) (not (and p n))) (cond ( (= "PORT_NUMBER" (cdr (assoc 2 x))) (setq p a) ) ( (= "SORT_ORDER" (cdr (assoc 2 x))) (setq n (atoi (cdr (assoc 1 x)))) ) ) (setq a (entnext a) x (entget a) ) ) (if (and p n) (setq l (cons p l) p nil q (cons n q) n nil ) ) ) (setq c 1) (foreach n (vl-sort-i q '<) (entmod (list (cons -1 (nth n l)) (cons 1 (padz (itoa c) 3)))) (setq c (1+ c)) ) ) ) (princ) ) (defun padz ( x n ) (if (< (strlen x) n) (padz (strcat "0" x) n) x) ) (princ) Amazing , that is what exactly i what. thank a lot. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 17, 2021 Share Posted May 17, 2021 You're welcome Quote Link to comment Share on other sites More sharing options...
Terry.T Posted May 24, 2021 Author Share Posted May 24, 2021 On 5/16/2021 at 9:24 PM, Lee Mac said: Another - (defun c:pno ( / a c i l n p q s x ) ;-------------------NEW ADD----------------------------------- (princ "\nPlease pick a block to numbering: ") (setq a1 (car (entsel))) (setq d1 (entget a1)) (setq e (assoc 8 d1)) ;-------------------NEW ADD----------------------------------- ; (if (setq s (ssget "_X" '((0 . "INSERT") (8 . "NUMBERING")))) ; (if (setq s (ssget "_X" '((0 . "INSERT") , e))) ; (if (setq s (ssget "_X" '((0 . "INSERT") (e) ))) (if (setq s (ssget "_X" '((0 . "INSERT") e))) (progn (repeat (setq i (sslength s)) (setq i (1- i) a (entnext (ssname s i)) x (entget a) ) (while (and (= "ATTRIB" (cdr (assoc 0 x))) (not (and p n))) (cond ( (= "PORT_NUMBER" (cdr (assoc 2 x))) (setq p a) ) ( (= "SORT_ORDER" (cdr (assoc 2 x))) (setq n (atoi (cdr (assoc 1 x)))) ) ) (setq a (entnext a) x (entget a) ) ) (if (and p n) (setq l (cons p l) p nil q (cons n q) n nil ) ) ) (setq c 1) (foreach n (vl-sort-i q '<) (entmod (list (cons -1 (nth n l)) (cons 1 (padz (itoa c) 3)))) (setq c (1+ c)) ) ) ) (princ) ) (defun padz ( x n ) (if (< (strlen x) n) (padz (strcat "0" x) n) x) ) (princ) May i learn more about "ssget" I am trying to let the computer know which layer i need and i set a value "E" to keep it, is it possible, if i change the coding like this? (not working) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 24, 2021 Share Posted May 24, 2021 The issue is that the ssget filter list is quoted as a literal list, and therefore the symbol 'e' will not be evaluated as a variable to yield the value it has been assigned, but will instead remain as a symbol. To better understand this behaviour, and how to alter the expression to evaluate the variable, you may wish to read my tutorial on The Apostrophe and the Quote Function. 1 Quote Link to comment Share on other sites More sharing options...
Terry.T Posted May 28, 2021 Author Share Posted May 28, 2021 On 5/24/2021 at 4:05 PM, Lee Mac said: The issue is that the ssget filter list is quoted as a literal list, and therefore the symbol 'e' will not be evaluated as a variable to yield the value it has been assigned, but will instead remain as a symbol. To better understand this behaviour, and how to alter the expression to evaluate the variable, you may wish to read my tutorial on The Apostrophe and the Quote Function. Thanks a lot about this i have update the app and it is works (defun c:pno ( / a c i l n p q s x ) ;-------------------NEW ADD----------------------------------- (princ "\nPlease pick a block to numbering: ") (setq a1 (car (entsel))) (setq d1 (entget a1)) ;-------------------NEW ADD----------------------------------- ;-------------------change------------------------------------- ; (if (setq s (ssget "_X" '((0 . "INSERT") (8 . "NUMBERING")))) (if (setq s (ssget "_X" (list '(0 . "INSERT") (assoc 8 d1)))) ;-------------------change------------------------------------- (progn (repeat (setq i (sslength s)) (setq i (1- i) a (entnext (ssname s i)) x (entget a) ) (while (and (= "ATTRIB" (cdr (assoc 0 x))) (not (and p n))) (cond ( (= "PORT_NUMBER" (cdr (assoc 2 x))) (setq p a) ) ( (= "SORT_ORDER" (cdr (assoc 2 x))) (setq n (atoi (cdr (assoc 1 x)))) ) ) (setq a (entnext a) x (entget a) ) ) (if (and p n) (setq l (cons p l) p nil q (cons n q) n nil ) ) ) (setq c 1) (foreach n (vl-sort-i q '<) (entmod (list (cons -1 (nth n l)) (cons 1 (padz (itoa c) 3)))) (setq c (1+ c)) ) ) ) (princ) ) (defun padz ( x n ) (if (< (strlen x) n) (padz (strcat "0" x) n) x) ) (princ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 28, 2021 Share Posted May 28, 2021 You're welcome - well done Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 28, 2021 Share Posted May 28, 2021 When in doubt I use all filters as cons this supports a variable by name and a value like "abc" or 1. Using '(( takes a little getting use to as per info by Lee. (setq ss (ssget "X" (list (cons 0 "LWPOLYLINE")(cons 8 mylayer) (cons 70 1) ))) (setq ss (ssget "X" (list (cons 0 "LWPOLYLINE")(cons 8 "Design") (cons 70 isClosed) ))) Quote Link to comment Share on other sites More sharing options...
