help in editing FakeDims.LSP
Afandy
20 hours ago, Afandy said:
http://www.cadtutor.net/forum/showthread.php?83532-How-to-filter-Edited-Dimensions
hi guys
this list finding Fake Dimension (override)
then change text color of them to Red
could any one help me to add changing Fill Color of text to Yellow or Active (Draw Frame Around Text) ?
great thanks for you
(defun C:test(/ i ss)
 (vl-load-com)
 (setvar "cmdecho" 0)
 (if (setq ss (ssget "X" '((0 . "DIMENSION") (-3 ("ACAD")))))
     (entmod (list (cons -1 (ssname ss (setq i (1- i)))) (list -3 (list "ACAD"))))
   (if (setq ss (ssget "X" '((0 . "DIMENSION") (-4 . "<AND")(-4 . "<NOT")(1 . "")(-4 . "NOT>")(-4 . "<NOT")(1 . "*<>*")(-4 . "NOT>")(-4 . "AND>"))))
         (PROGN
       (setq iOG(vlax-ename->vla-object (ssname ss (setq i (1- i)))))
         (vlax-put-property iOG "textcolor" 1)
         (vlax-put-property iOG 'TextFill :vlax-true)
         (vlax-put-property iOG 'TextFillColor 2)
     (alert "Not find Edited Dimensions!")
 (vl-load-com)
         (PROGN
Thank you sir
  • Thanks 1
