Hi everyone,
I've been using initget with entsel in my codes so that users can choose option inside entsel, now I need to perform it with ssget, to do this I wrote :
(initget "Setting")
(setq ss (ssget"\nSelect objects  [Setting]: "))
but it didn't work, does someone know what the problem is?
Edited by amir0914
SSget works with filters like objects Circle Arc Line, you have to make a choice before running ssget then you can use your filter.
So create a initget with what you want.
Then do the ssget with correct filter, can not provide more info as do not know what it is your trying to use.
Expanding on what BIGAL said
From AutoCAD Help
initget (AutoLISP) https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-9ED8841B-5C1D-4B3F-9F3B-84A4408A6BBF
lists all the lisp functions it works with. No selection set functions are included.
ssget (AutoLISP) https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-0F37CC5E-1559-4011-B8CF-A3BA0973B2C3
describes using ssget with a filter list
and
About Selection Set Filter Lists (AutoLISP) https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-7BE77062-C359-4D01-915B-69CF672C653B
gives a few examples and provides related topics and links to help you make whatever filter you need.
Just like @BIGAL and @tombu said, ssget isn't compatible with prompting messages like entsel does. Probably in the future it might change.
Edited by Jonathan Handojo
You may also wish to refer to my explanation and suggestion posted here.
  • Like 2
