Steven P Posted May 6, 2021 Share Posted May 6, 2021 Good morning, I have a lisp that will open another drawing and then does stuff, works very well for me, until the file to be opened has a warning dialogue box popping up. This will halt anything else that is happening until the 'OK' or whatever button is pressed... normally this is OK, until I want to set the lisp running and go for a coffee only to come back and find it has all been paused for 5 minutes. So is there a way to temporarily disable pop up dialogue warning boxes as a file is opened. Might also be good if this can take into account any crashes that might occur (an error function probably). Then I can get a coffee while CAD is doing stuff (this week the warning has been "One of more SHX files are missing" in an xref I don't own but it isn't worth the time to chase to get them, as an example of what pauses things - I don't want to press the never show me this warning again just in case I need to see it later) Hope that makes sense Thanks Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 6, 2021 Share Posted May 6, 2021 (edited) SET FILEDIA TO 0 MAYBE? --EDIT-- What is the warning? this suppresses the read only https://www.cadforum.cz/en/qaID.asp?tip=5666 Edited May 6, 2021 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
