Quik&Easy Posted May 5, 2021 Share Posted May 5, 2021 I'd like to stretch/shorten an egg shape along the X axis only. The only work around I've found is to isolate the desired geometry and import it in to a new drawing, manually figuring the required X axis scale addition/reduction then completing the import. This in not an ellipse but an organic shape simplified to just a few entities. Stretch just moves the object over. I've searched the menu options in Bricscad relating to scale command, as well as searching the forums on the Bricscad site without finding an answer so thought I'd ask here. I'm using Classic Version 19. test egg stretch.dwg Quote Link to comment Share on other sites More sharing options...
guran Posted May 5, 2021 Share Posted May 5, 2021 Make a block of it. Then you can scale it in X or Y direction in properties. 1 Quote Link to comment Share on other sites More sharing options...
Quik&Easy Posted May 5, 2021 Author Share Posted May 5, 2021 Thank you, I'll explore that option. I haven't used blocks so am not fluent with them but will try that idea. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 6, 2021 Share Posted May 6, 2021 Like Quick&Easy block, recsale X or Y then explode and purge temporary block name. Quote Link to comment Share on other sites More sharing options...
