tombu Posted May 10, 2021 Posted May 10, 2021 Try: (defun c:ZSnapOld ( / pt1 pt2) (setq pt1 (getpoint "\nSelect First Window Point: ")) (setq pt2 (getcorner pt1 "\nSelect Second Window Point: ")) (command "._zoom" "_w" pt1 pt2) ; end zoom ) It should snap to whatever osnap settings you're alteady using. Sometimes simple is best. 1 Quote
tombu Posted May 10, 2021 Posted May 10, 2021 This more complicated version will also temporarily toggle Osnaps on while Zooming if needed for newer versions. ; Zoom Window using Osnap settings by Tom Beauford ; Macro: ^P(or C:ZSnap (load "ZSnap.lsp"));ZSnap ; Command line: (load "ZSnap.lsp") ZSnap (defun c:ZSnap ( / *error* osmode pt1 pt2) (defun *Error* (msg) ; embedded defun (setvar 'osmode osmode) (if (/= s "Function cancelled") (princ (strcat "\nError: " msg)) ) (princ) ) (setq osmode (getvar 'osmode)) (if (> (getvar 'osmode) 16384) (setvar 'osmode (- osmode 16384)) ) (setq pt1 (getpoint "\nSelect First Window Point: ")) (setq pt2 (getcorner pt1 "\nSelect Second Window Point: ")) (command "._zoom" "_w" pt1 pt2) ; end zoom (setvar 'osmode osmode) ) Osnap bitcodes changed when Geometric CEnter osnap was added so you will need to find the old bitcode setting to Suppress the current running object snaps in older versions. 1 Quote
Dana W Posted May 10, 2021 Posted May 10, 2021 All this code popping up. Looks a lot more complicated than I first thought. Quote
sketch11 Posted May 10, 2021 Author Posted May 10, 2021 Thanks for assisting again tombu. I tried both of the above code snippets on AutoCAD 2021 and both work. I'll try on a previous version at a later stage. Cheers. Quote
sketch11 Posted May 14, 2021 Author Posted May 14, 2021 Hi tombu, thanks, both of these worked on a previous version. Quote
