Anushka Posted April 30, 2021 Posted April 30, 2021 (edited) Can someone give me an explanation of how I do it so that when I click on a certain part of image_button it will return me a viable of that part. Something like that LSP (defun c:sldteste ( ) (cond ( (<= (setq dcls (load_dialog "slidetest.dcl")) 0) (alert "ERROR") ) ( (not (new_dialog "dcl_img_test" dcls "" (cond ( *screenpoint* ) ( '(-1 -1) )))) ;(not (new_dialog "FTTx_ImagemtoGoogle" dcls)) (alert "ERROR") ) (t (setq w (dimx_tile "img_sld") h (dimy_tile "img_sld") ) (start_image "img_sld") (fill_image 0 0 w h 0) (slide_image -290 -440 (* w 2) (* h 2) "C:\\utilitarios\\mapabrasil2.sld") (end_image) (if (eq (start_dialog) 1) (prompt "ok") ) ) ) ) DCL butt01 : button { width = 15; height = 2; fixed_width = true; alignment = centered; } dcl_img_test : dialog { label = "Image teste"; spacer; : row { : boxed_column { label = "Imagem Ilustrativa"; width = 5; : row { spacer; : image_button { key = "img_sld"; width = 70; height = 30; color = 0; fixed_width=true; fixed_height=true; aspect_ratio = 1; alignment = centered; } spacer; } } } : row { ok_cancel; } spacer; } mapabrasil2.sld Edited April 30, 2021 by Anushka Quote
BIGAL Posted April 30, 2021 Posted April 30, 2021 An example also some 3x3 & 4x4 dcl. ;;; Uses DD3X3.DCL for the dialogue definition. The ;;; slide images are in list ai_pts_lst.120 ; ctone is slb library name (tlds) is slide name in library ; use individual slide name if no library (setq ai_pts_lst '("ctone(TLDS)" "ctone(dsdn)" "ctone(trds)" "ctone(dsr)" "ca3blank" "ctone(DSL)" "ctone(blds)" "ctone(dsup)" "ctone(brds)") ) (setq ai_pts_lst2 '("33sq1" "33sq2" "33sq3" "33sq4" "33sq5" "33sq6""33sq7" "33sq8" "33sq9" )) (defun sq_pick () (cond ((= ans "33sq1")(setq ang1 4.7125)(setq ang2 0.0)(tr)) ((= ans "33sq2")(tm)) ((= ans "33sq3")(setq ang1 3.1417)(setq ang2 4.7125)(tr)) ((= ans "33sq4")(tm)) ((= ans "33sq5")(princ "run other clean up")) ((= ans "33sq6")(tm)) ((= ans "33sq7")(setq ang1 1.5708)(setq ang2 0.0)(tr)) ((= ans "33sq8")(tm)) ((= ans "33sq9")(setq ang1 1.5708)(setq ang2 3.1417)(tr)) ) ) ; calculates next slide (defun alan4 () (setq x (+ x 1)) (setq sldname (nth x ai_pts_lst)) ) ; third step ; set up slide libraray (defun ai_ptype_start () (setq x -1) (foreach pts0 ai_pts_lst2 (alan4) (start_image pts0) (slide_image 0 0 (- (dimx_tile pts0) 1) (- (dimy_tile pts0) 1) sldname) (end_image) ) ) ; this is second step (defun ai_ptype_main (/ globals) (ai_ptype_start) ;now check each sq if picked then run alan2 (foreach pd0 ai_pts_lst2 (action_tile pd0 "(done_dialog)(setq ans $key)") ) (start_dialog) ) ; this is first step (if (= w2 nil)(setw2)) (setq app "dd3x3.dcl") (if (= id_3x3 nil) (progn (setq dcl_id (load_dialog app)) (setq id_3x3 dcl_id) ) ) (if (not (new_dialog "dd3x3" id_3x3)) (exit)) (ai_ptype_main) (sq_pick) (setq *error* old_error old_error nil) DD4X3.zip 1 Quote
Anushka Posted May 1, 2021 Author Posted May 1, 2021 16 hours ago, Grrr said: Heres somewhat related topic. Thanks @Grrr This worked perfectly!!! Quote
Grrr Posted May 1, 2021 Posted May 1, 2021 1 hour ago, Anushka said: Thanks @Grrr This worked perfectly!!! Glad it helped, I remember coding this out after I've got the answer in that topic. Quote
