Anushka Posted April 30, 2021 Share Posted April 30, 2021 (edited) Can someone give me an explanation of how I do it so that when I click on a certain part of image_button it will return me a viable of that part. Something like that LSP (defun c:sldteste ( ) (cond ( (<= (setq dcls (load_dialog "slidetest.dcl")) 0) (alert "ERROR") ) ( (not (new_dialog "dcl_img_test" dcls "" (cond ( *screenpoint* ) ( '(-1 -1) )))) ;(not (new_dialog "FTTx_ImagemtoGoogle" dcls)) (alert "ERROR") ) (t (setq w (dimx_tile "img_sld") h (dimy_tile "img_sld") ) (start_image "img_sld") (fill_image 0 0 w h 0) (slide_image -290 -440 (* w 2) (* h 2) "C:\\utilitarios\\mapabrasil2.sld") (end_image) (if (eq (start_dialog) 1) (prompt "ok") ) ) ) ) DCL butt01 : button { width = 15; height = 2; fixed_width = true; alignment = centered; } dcl_img_test : dialog { label = "Image teste"; spacer; : row { : boxed_column { label = "Imagem Ilustrativa"; width = 5; : row { spacer; : image_button { key = "img_sld"; width = 70; height = 30; color = 0; fixed_width=true; fixed_height=true; aspect_ratio = 1; alignment = centered; } spacer; } } } : row { ok_cancel; } spacer; } mapabrasil2.sld Edited April 30, 2021 by Anushka Quote Link to comment Share on other sites More sharing options...
Grrr Posted April 30, 2021 Share Posted April 30, 2021 Heres somewhat related topic. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 30, 2021 Share Posted April 30, 2021 An example also some 3x3 & 4x4 dcl. ;;; Uses DD3X3.DCL for the dialogue definition. The ;;; slide images are in list ai_pts_lst.120 ; ctone is slb library name (tlds) is slide name in library ; use individual slide name if no library (setq ai_pts_lst '("ctone(TLDS)" "ctone(dsdn)" "ctone(trds)" "ctone(dsr)" "ca3blank" "ctone(DSL)" "ctone(blds)" "ctone(dsup)" "ctone(brds)") ) (setq ai_pts_lst2 '("33sq1" "33sq2" "33sq3" "33sq4" "33sq5" "33sq6""33sq7" "33sq8" "33sq9" )) (defun sq_pick () (cond ((= ans "33sq1")(setq ang1 4.7125)(setq ang2 0.0)(tr)) ((= ans "33sq2")(tm)) ((= ans "33sq3")(setq ang1 3.1417)(setq ang2 4.7125)(tr)) ((= ans "33sq4")(tm)) ((= ans "33sq5")(princ "run other clean up")) ((= ans "33sq6")(tm)) ((= ans "33sq7")(setq ang1 1.5708)(setq ang2 0.0)(tr)) ((= ans "33sq8")(tm)) ((= ans "33sq9")(setq ang1 1.5708)(setq ang2 3.1417)(tr)) ) ) ; calculates next slide (defun alan4 () (setq x (+ x 1)) (setq sldname (nth x ai_pts_lst)) ) ; third step ; set up slide libraray (defun ai_ptype_start () (setq x -1) (foreach pts0 ai_pts_lst2 (alan4) (start_image pts0) (slide_image 0 0 (- (dimx_tile pts0) 1) (- (dimy_tile pts0) 1) sldname) (end_image) ) ) ; this is second step (defun ai_ptype_main (/ globals) (ai_ptype_start) ;now check each sq if picked then run alan2 (foreach pd0 ai_pts_lst2 (action_tile pd0 "(done_dialog)(setq ans $key)") ) (start_dialog) ) ; this is first step (if (= w2 nil)(setw2)) (setq app "dd3x3.dcl") (if (= id_3x3 nil) (progn (setq dcl_id (load_dialog app)) (setq id_3x3 dcl_id) ) ) (if (not (new_dialog "dd3x3" id_3x3)) (exit)) (ai_ptype_main) (sq_pick) (setq *error* old_error old_error nil) DD4X3.zip 1 Quote Link to comment Share on other sites More sharing options...
Anushka Posted May 1, 2021 Author Share Posted May 1, 2021 16 hours ago, Grrr said: Heres somewhat related topic. Thanks @Grrr This worked perfectly!!! Quote Link to comment Share on other sites More sharing options...
Grrr Posted May 1, 2021 Share Posted May 1, 2021 1 hour ago, Anushka said: Thanks @Grrr This worked perfectly!!! Glad it helped, I remember coding this out after I've got the answer in that topic. Quote Link to comment Share on other sites More sharing options...
