jt6572 Posted April 29, 2021 Share Posted April 29, 2021 Hi all I have a dwt in which I have all of the scales we need, but it seems like whenever I create a drawing from it and save it only seems to retain the scales used. A dodgy workaround I have is a tiny mtext with all required scales as annotative scales, but that gives scales of eg.; 1:1000 X_Ref, which isn't cool as I use annotative text.... Could somebody please tell me how I can have them all stay in the drawings?! thank you Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted April 29, 2021 Share Posted April 29, 2021 I was under the impression that all annotative scales, used or not, are saved with a drawing. At least, I've never noticed them disappearing. Look into the SAVEFIDELITY variable and see what it's set to in your template. Without more clues, I'm not sure how to proceed. Annotation is not one of my strong suits. Quote Link to comment Share on other sites More sharing options...
jt6572 Posted April 29, 2021 Author Share Posted April 29, 2021 (edited) Hi CyberAngel, thanks very much for your help. the savefidelity is set to 1. which is what I assume a toggle meaning it is on? in the interim, is there a way to copy scales into a drawing? design centre maybe? will have a quick look.... ...nope. Edited April 29, 2021 by jt6572 Quote Link to comment Share on other sites More sharing options...
tombu Posted April 30, 2021 Share Posted April 30, 2021 If you're talking about the [Default Scale List…] on the [User Preferences] tab in Options you can restore them with the SCALELISTEDIT command. 1 1 Quote Link to comment Share on other sites More sharing options...
jt6572 Posted May 1, 2021 Author Share Posted May 1, 2021 16 hours ago, tombu said: If you're talking about the [Default Scale List…] on the [User Preferences] tab in Options you can restore them with the SCALELISTEDIT command. Hi Tombu, yes that is it. thanks very much. :) Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 13, 2021 Share Posted May 13, 2021 On 4/28/2021 at 7:33 PM, jt6572 said: Could somebody please tell me how I can have them all stay in the drawings?! We have a custom routine that deletes all unused scales at drawing load time, and loads a set that is defined elsewhere. So that all drawings that are opened will then contain the default set stored, plus any in use. This was due to the bloat bug that caused some drawings to contain hundreds of scale list entries. Quote Link to comment Share on other sites More sharing options...
tombu Posted May 13, 2021 Share Posted May 13, 2021 (edited) 1 hour ago, rkmcswain said: We have a custom routine that deletes all unused scales at drawing load time, and loads a set that is defined elsewhere. So that all drawings that are opened will then contain the default set stored, plus any in use. This was due to the bloat bug that caused some drawings to contain hundreds of scale list entries. I used a heavily modified version of Jimmy Bergmark's PersonalMtextSymbols.LSP to do that for many years but he's noted it stopped working in 2019 version. Still doesn't work for scales in 2021 but does add the Mtext symbols. If your's is still working I'd love to see it. Edited May 13, 2021 by tombu Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 13, 2021 Share Posted May 13, 2021 Ours is a custom DLL file from a contracted programmer, so can't share. But to illustrate the possibilities, ours reads a config file and custom tailors the list to the discipline of the user. Quote Link to comment Share on other sites More sharing options...
