bsimpson Posted April 28, 2021 Posted April 28, 2021 Hi, I have a lisp routine which aligns a point to a alignment in civils3d. The aligned point is perpendicular to the alignment but I need the rotation of the point to be parallel to the alignment. Is there a way the lisp routine could be written to rotate the cogopoints parallel to the alignment? Bsimpson ptsalign.LSP Quote
hosneyalaa Posted April 28, 2021 Posted April 28, 2021 50 minutes ago, bsimpson said: Hi, I have a lisp routine which aligns a point to a alignment in civils3d. The aligned point is perpendicular to the alignment but I need the rotation of the point to be parallel to the alignment. Is there a way the lisp routine could be written to rotate the cogopoints parallel to the alignment? Bsimpson ptsalign.LSP 2.49 kB · 1 download Please put the question here And attached drawing example https://forums.autodesk.com/t5/civil-3d-customization/bd-p/190 Quote
rkmcswain Posted April 28, 2021 Posted April 28, 2021 @bsimpson - to me, this routine does rotate the point so that it is parallel to the alignment. 1 Quote
rkmcswain Posted April 28, 2021 Posted April 28, 2021 @bsimpson - and it has options built in to do other rotations. 1 Quote
bsimpson Posted April 28, 2021 Author Posted April 28, 2021 (edited) Thanks for that discovery, It is close to what I am looking for. Edited April 28, 2021 by bsimpson Quote
