Dear team,
I have more than 200 object (as image attached) in a cad file.
This object have line and text only.
I want to make block of each that object.
Automatically make block and keep
Block name series like c1,c2. Without change position, location or orientation.
Thanks
I'm guessing the 200 objects are at different locations and you want to make them blocks at their perspective locations?  This should be what your looking for.
; Creates a C_# block from selected objects at LL point
(defun C:foo (/ SS i BlkName LL UR oLL oUR)
  (setvar 'clayer "0")
  (if (setq SS (ssget))
      (BBox) ;overall bounding box of selected objects
      (setq i 1 BlkName (strcat "C" (itoa i)))
      (while (tblsearch "BLOCK" BlkName)
        (setq BlkName
              (strcat "C" (itoa (setq i (1+ i))))
      (vl-cmdf "_.Block" BlkName "_non" LL SS "")
      (vl-cmdf "_.Insert" BlkName "_non" LL 1 1 0)
      (print (strcat BlkName " Is Made"))
  (ENDCHECK)
;Get Bounding box of entity
(defun BBox (/ i)  ; = Object's Bounding Box corners
  (setq i 0)
  (vla-getboundingbox (vlax-ename->vla-object (ssname SS i)) 'minpt 'maxpt)
  (setq
    oLL (vlax-safearray->list minpt)  ; Object's Lower Left
    oUR (vlax-safearray->list maxpt)  ; Object's Upper Right
  (setq LL oLL UR oUR)  ; initial overall LL & UR [of first object]
  (repeat (1- (sslength SS))
    (setq i (1+ i))
    (setq
    (setq
      LL (mapcar 'min oLL LL)           ; least of each component
      UR (mapcar 'max oUR UR)           ; greatest of each component
my 2 cents don't just use a generic block name with a rolling #. try to make them unique. like Drawing_name_C# or something. If you use these block in your daily process. copying C3 from one project to another will not be good since its already defined in both.
Just wondering where those 200 tables came from. Seems like they'd already be blocks with attributes or AutoCAD or Civil tables.
Cannot imagine someone drawing and filling in values for every one of them when they could have been added programmably.
Sir Thats 200 table came from Mx Road software.
