Steven P Posted April 22, 2021 Posted April 22, 2021 Not sure exactly what you are looking for here, is it just the lines of code which make up the 7 highlighted items (1 to 5 are all the same if so) which you can add to a DCL code, do you want the code to make up a a whole dcl thing (the dialogue box) to add to a LISP code, or do you want the whole lot from knowing nothing. Quote
Jonathan Handojo Posted April 22, 2021 Posted April 22, 2021 Maybe he just wants to know what those do to the codes. In the Visual LISP IDE, you can select a portion of the code, and go to Tools > Format Code... Or for short, Ctrl + F. When you do this, the following should happen (I only know some not all). #1 limits the maximum number of characters you can have in one single line. #2 is the number of spaces for indentation when continuing an opening parantheses in a new line. #4 is the starting location of all comments found within that line (or so I thought.) #7 is how your list will look when you have a list to be formatted. (I think) I'll need more education on the rest Quote
