Error function
sivapathasunderam
1.) Is this a typical error function ?
2.) How this works? (when there is error on my code, this will break the program correct)
(defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (prompt (strcat "\nError: " errmsg))
    ); if
3.) Can i add this to my lisps, if required when it's required to update further . . .
1. Yes
2. If the error contains any of the following in the wcwatch it will not display the error message that is all.  if its a different error it will display that error.
    The lisp has already stopped due to the error.
Example:
type ZE command
Autocad zoom extents and waits for object selection.
*hit esc key*
error: Function Cancled
3. Yes just add it before or after your code. more details here
        or here
This is my zoom Extents macro it has a second "command" to zoom to object if i select anything but usually just hit esc and dont want to see an error when i do.
;; Zoom Extents Then Zoom to object if needed
(defun C:ZE (/ SS *error*)
    (if (not (member errmsg '( "Console Break" "Function cancelled")))
      (princ (strcat "\nError: " errmsg))
  (vl-cmdf "_.Zoom" "E")
  (if (setq SS (ssget))
      (vl-cmdf "_.Zoom" "OB" SS "")
      (vl-cmdf "_.Zoom" "0.95x")
Edited by mhupp
A minor point, but always be sure to declare the redefined *error* symbol as local to the function (i.e. within the list of local arguments & variables), so that the scope of the redefinition is limited to the function in which it is redefined; without this declaration, you are redefining the error function globally and therefore affecting all other AutoLISP functions defined within the active document namespace.
